Thu Mar 22, 2012Total posts : 2
swetalakra
swetalakra
Topic: Which types of pipes are suitable for internal plumbing systems for residential homes?
i need simple and design decent design so that even the style goes out it would look beautiful
The comment above talks about the article   "Which types of pipes are suitable for internal plumbing systems for residential homes?"
Fri Mar 23, 2012Post  #1
Dear Lakra
        The enquire send by you is not clear, please write in detail.
Tue Mar 27, 2012Post  #2
Leela Dhar
Leela Dhar
Post subject: Tiles
I will const my home in terrace 3rd florr by fabricated technique.
I want to use tiles in open terrace and my two room.
so pl suggest  which tile is the best for open terrace.
I already seen thermotex tiles which is only white shade but I want some colourful.
So pl write.
Leela Dhar
3465
Kindly guide us for which type of flooring like marble, vitrified tiles is suita
Last answer on 4/12/2010 4:08:33 PM. by M Jindal. Forum started by Sanjay jain
1989
PLUMBING
2703
home security systems
Last answer on 7/3/2020 10:55:36 PM. by S L Gupta (Civil Engg). Forum started by farrukh tahir
9174
1621
i am asking for staircause ...Run=5feet,Raise=9feet......in this situtation ..wh
Last answer on 4/22/2016 12:12:17 PM. by S L Gupta (Civil Engg). Forum started by Selvan
1826
3267
11188
Which plumbing pipe best for residential purpose?GI(Jindal C/TATA C)alont with (
Last answer on 4/22/2016 11:45:48 AM. by S L Gupta (Civil Engg). Forum started by Sunny Bansal
1960
how to do gas piping for a residential ground floor independent building should
Last answer on 12/26/2011 7:59:32 PM. by S L Gupta (Civil Engg). Forum started by elizabeth
1832
Last answer on 4/6/2017 10:05:57 PM. by Saurav anand. Forum started by prashant
1781
My house is under construction and i have to go for plumbing therefore i want to
Last answer on 9/17/2014 10:59:54 PM. by JAI PRAKASH. Forum started by Avinash Sharma
2866
i want to set my share trading system in my bed room can you suggest me how am i
Last answer on 12/31/2020 2:19:02 AM. by Sudha. Forum started by vijendra
2337
I want a residential home design low estimate
Last answer on 4/23/2013 11:32:19 AM. by S L Gupta (Civil Engg). Forum started by Dipankar Gharami
2466
2646
I am Sharath my date of birth is 15 Oct 1993 which direction suitable for study
Last answer on 12/23/2020 11:56:31 PM. by Abhishek Vohra. Forum started by sharath mb
1815
door shutter
Last answer on 12/4/2014 1:10:41 AM. by JAI PRAKASH. Forum started by sunil kumar
1757
i what type of flooring is suitable for kitchen?
Last answer on 9/6/2011 2:39:03 PM. by S L Gupta (Civil Engg). Forum started by dinesh
1948
Solenoid valves for home water piping
Last answer on 3/10/2013 8:28:59 PM. Forum started by Nilanshu
Sewerage
Sewerage & Plumbing System
Checklist for Plumbing
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
Which are space parameters for plumbing and sanitary fittings?
The following are various space parameters for plumbing and sanitary fitting:
