Home -> Forums -> Vastu -> Drawing Room -> underground tank
underground tank
Wed Feb 20, 2013Total posts : 1
Subramani P
Subramani P
Topic: underground tank
Dear,
i am planning to buy a apartment. This flat is in second floor. The 70% of the floor is the flat and the remaining 30% is open terrace. The Property is south facing (road is on south side of the building), while the main entrance of the flat is East facing. Kitchen is in the North-West corner. The stairs in to the North-east of the flat and the over-head tank is above the stair case. Also the Underground tank is in the South East. The Borewell is in the right place (North East)
As per vaasthu, the underground tank and Overhead tank should not be in south east.
Is this property good to take. I liked the property and i am unaware whether this will suit us.
Please advise.
thank you
Subramani
Tue Feb 26, 2013Post  #1
Pavan
Pavan
Post subject: Underground Tank
Hello Subramani,
Before deciding on the direction, please perform the below steps to demark the exact zones. Take the plan of the entire building including the compound wall. Place a 3x3 grid on it. This will give you the exact zone of the Building plot. Once this is done it gives a clear picture as to which zone has Stair case or Underground tank. Since you are thinking of the second floor flat, in this case the ground energies matter a lot.
IF you have already done the above excersise
As per vastu Shastra, the North and east should be lighter, where as the South and West should be heavier. Underground water tank is a form of cavity which reduces earth element. SE being the direction of Fire element water in this direction creates a imbalance. Also as you said stairs are in the NE, that is addition of excessive Earth element in the source zone (Zone of water element). So as per your description two zones of the vastu are already impacted and since this is a apartment you cannot change the UG tank as well as the stair case.
My suggestion here would be talk to the inmates of the other flats residing in this building and know their experience before making a decision. Also the impact will not be immediate this will be over a period of time.
Regards.
Pavan Matkar (pmatkar@gmail.com)
Wastu Wimarsh
5055
1794
Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
Last answer on 10/25/2013 12:34:54 PM. by S L Gupta (Civil Engg). Forum started by Viral
2058
2187
2483
3119
2119
2634
5207
2450
2138
Last answer on 12/30/2013 2:23:18 PM. by S L Gupta (Civil Engg). Forum started by niyaz madiwale
990
I want to construct an underground tank for rain harvesting. Approx size 10x10x1
Last answer on 5/24/2017 12:14:59 PM. by S L Gupta (Civil Engg). Forum started by Rajagopal
990
2611
Vastu for an apartment -- help required!!!
Last answer on 12/31/2020 2:19:12 AM. by anil. Forum started by C A N Naick
1593
I have an underground water tank at the northwest of my house which is not recom
Last answer on 9/13/2010 4:25:10 PM. Forum started by Asha Khaitan
2121
2252
2219
13538
3676
3086
2316
2345
3406
2265
5121
1845
7104
2554
2143
1723
1821
1833
2073
5822
2676
7305
7537
2704
Vastu for Water Tank
Preventive
Reasons of dampness
Sewerage
Sewerage & Plumbing System
Importance
