Plumbing
Tue May 06, 2014
mohammed sadhiq ali
Topic: underground water sump or tank
merits and demerits of using vetrifed tiles in underground water sump
or tanks.
construction and maintenance of underground water sump or tank
Tue May 06, 2014
Dear Ali
If ceramic tiles laid properly with proper joint filled than it is easy to clean the tank when required.
3370
Last answer on 7/3/2020 11:28:14 PM. by
Y Mitran
13537
Last answer on 11/3/2021 7:56:28 AM. by
mohammed sadhiq ali
2482
Last answer on 6/3/2021 3:08:10 AM. by
Shreevardhan
2185
Last answer on 1/19/2022 6:10:39 AM. by
HANUMAN
3119
Last answer on 9/19/2014 9:38:22 AM. by
Unoara Design Hub
nishant shah
6579
Last answer on 10/16/2014 12:42:44 AM. by
NV MANI
5207
Last answer on 9/17/2012 4:28:54 PM. Forum started by
Amatuer
2448
Last answer on 10/3/2012 9:58:30 PM. by
JASBIR MALHOTRA
2633
Last answer on 1/20/2021 8:48:02 PM. Forum started by
drlpsingh
2118
Last answer on 9/13/2010 4:33:09 PM. Forum started by
Asha Khaitan
2058
sumit
2218
Last answer on 2/4/2015 2:01:32 PM. by
MUNNAWAR
3497
Last answer on 2/21/2021 8:33:40 AM. by
rameshkumar
rameshkumar
5733
Last answer on 7/4/2020 2:50:48 AM. by
NV MANI
NV MANI
4384
Last answer on 7/4/2020 2:05:07 AM. Forum started by
NV MANI
3079
Last answer on 1/2/2021 5:22:54 AM. Forum started by
NV MANI
40516
Last answer on 7/4/2020 2:50:25 AM. by
har
5459
Underground water sump
Last answer on 2/27/2015 11:50:23 AM. by
revadi
hb
1995
Hi. I have built a Fresh water underground sump in the South east corner of the
Last answer on 3/1/2011 3:05:47 PM. by
Mohini Sharma
m naveen
6270
Water Tank Quality
Last answer on 7/22/2021 5:19:42 PM. by
George Turner
Raman Mittal
3114
Hot Water Tank
Last answer on 1/9/2021 1:51:22 PM. by
Fox
Kanhaiya
2914
Sand in Water
Last answer on 12/31/2020 1:56:57 AM. by
yogiagarwal
Kanhaiya
3380
Diverters for Bathroom
Last answer on 11/4/2020 4:13:51 AM. by
perryjoseph
2561
Last answer on 7/4/2020 3:36:21 AM. Forum started by
pallubc2
2145
Last answer on 7/4/2020 2:51:01 AM. by
Hema
40516
har
2083
GI pipe Vs CPVC pipeline
Last answer on 7/9/2018 12:35:54 AM. by
Rahul
2930
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
1755
Last answer on 4/22/2016 11:37:09 AM. by
jameel5
2079
Toilets
Last answer on 7/26/2015 4:31:26 AM. by
sandeep yadav
sandeep yadav
1988
Wall mounted cummod vs normal
Last answer on 7/2/2014 11:29:45 PM. by
awdhesh
2775
Last answer on 1/25/2014 12:56:57 PM. by
chrome
1854
Last answer on 5/16/2013 2:56:28 PM. by
sam_m400
3074
Swimming pool
Last answer on 10/30/2012 12:08:21 PM. by
rajesh
2541
water softner
pallubc2
2681
commode type and flush type
Last answer on 5/26/2012 9:05:44 AM. by
pallubc2
4193
to shut off water to house
Last answer on 3/28/2011 9:36:11 PM. by
chris
chris
Vastu for Water Tank
Reasons of dampness
60 Tips to Save Water
Sewerage & Plumbing System
Water for Construction
Rain Water Harvesting
