Home -> Forums -> Construction -> Start Construction -> underground water tank
Fri Aug 01, 2014Total posts : 0
gaurav
gaurav
Topic: underground water tank
Dear Experts,
i would like to ask about construction of underground rcc water tank
the area where i can built is 9ft length, 3ft wide, 4 ft depth.
i would like to know the rcc walls should be used with which rcc bars specification & which water proofing chemical shall i use & as per my research it would store approx 900ltrs water if i construct 4" rcc walls all side & i want to know what specification shall i use to cover it as it would be having load as it will be constructed in ground stilt parking area.
thank you experts for ur valuable feedback
3126
2492
2189
2065
2123
2639
5212
2452
5066
2140
Last answer on 12/30/2013 2:23:18 PM. by S L Gupta (Civil Engg). Forum started by niyaz madiwale
2259
1599
I have an underground water tank at the northwest of my house which is not recom
Last answer on 9/13/2010 4:25:10 PM. Forum started by Asha Khaitan
3974
water proofing of water tank
3374
13556
1977
I want to construct underground water tank of 6'x6'x6'. Please give cost estimat
Last answer on 7/18/2013 3:45:44 PM. by Neeraj Sharma. Forum started by Neeraj Sharma
2382
water tank
1738
1941
2480
3306
3320
4449
4021
2246
2724
4233
5205
2394
2320
2024
2463
2142
3215
2073
12543
2187
2029
2749
Vastu for Water Tank
Preventive
Reasons of dampness
60
60 Tips to Save Water
Water for Construction
Sewerage
Sewerage & Plumbing System
Rain
Rain Water Harvesting
