urgent advise required
Tue May 27, 2014
wrighbed
Topic: urgent advise required
most of the rods of the columns on the roof of the ground floor is chopped off by some miscreants.. nw i am plaaning to start construction what should be done?what would be the effective way to make it strong
Tue May 27, 2014
Post subject: urgent advise
Hello..! Wrighbed, Remove by chiselling, the concrete near col. rods and diagonally at least 1'6" long, after that join the rods of same diameter by welding up to 15" with new column rods...regards
601
There is an urgent need to complete a history task, can someone advise a service
Last answer on 7/26/2021 5:46:43 AM. Forum started by
Finn Smith
2149
i want office furniture (desk cabin desk & cbinet storege)colour combination of
Last answer on 2/23/2022 1:50:41 AM. by
savani
1870
Last answer on 3/28/2016 3:13:41 PM. by
Pankaj
2340
How to Maintain Air Conditioner?
Last answer on 6/29/2021 4:36:51 AM. by
DavidFlores18
V K GUPTA
3084
Foundation
kamal
2281
Last answer on 7/11/2020 8:09:13 PM. by
Vinay
Vinay
1943
Cracks in the slab - urgent help required
Last answer on 7/5/2013 4:03:51 PM. by
vamsi
vamsi
2507
sir send me urgent front design for my house plzzzzzzzzzzzz sir send send on m
Last answer on 3/27/2012 5:00:14 PM. by
Swati Satija
syed furquan
2840
HOUSE MAP
Last answer on 7/3/2020 10:37:26 PM. by
Pankaj
2009
Last answer on 7/3/2020 10:54:45 PM. by
zakia sultana
1791
Hi Dear I need a 15*30 Plan URGENT. Can anyone hlepl
Last answer on 9/21/2015 11:51:48 AM. by
Manoj
1447
RCC Slab Metal Requirement
Last answer on 6/8/2016 11:25:12 PM. by
Mohan
Mohan
2547
Last answer on 3/2/2015 12:09:44 PM. by
Alok
2205
Last answer on 12/14/2010 7:35:48 PM. Forum started by
Rakshit
1928
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
2356
Autocad Training at Home.
Last answer on 7/3/2020 11:53:21 PM. by
PRIYAVADAN NAIR
1713
For weathering tiles at terrace for 1200 sq feet. what are all material require,
Last answer on 10/11/2013 9:29:39 PM. by
guna
2808
building a house
nashir
Metal,Cement & Jalli Requirement for RCC Slab Size 70'x26' = 1820
Last answer on 6/11/2016 12:26:27 PM. by
Mohan
2451
