Home -> Forums -> Construction -> Raw Material -> urgent : huge problem - best way to reduce cost diff : pls help
Mon Dec 14, 2015Total posts : 2
sushantsah
sushantsah
Topic: urgent : huge problem - best way to reduce cost diff : pls help
i have a 2400 sqft plot with 25 ft decent wide road in front,
in which i wanna get 3400 sqft construction (so you can have rough idea that i need decent amount of material in quantity)
but from main highway to my lane, in our colony lanes, at middle there are 2 bends which are quite narrow, not possible for large truck or dumper to come, but ok for tractor and mini truck.
Now i inquired for best rates for brick and dust and bazree,
brick truck is verylong that brings 13000 bricks and bazree from yamuna himachal brings 500 ft bazree in huge dumpers.
Now they cannot come directly to my plot because of bends in between.
What to do, find a plot empty (no one is nearby atleast 500 mtrs as colony is already developed without vacant plots) and get unload of material from big dumper/truck to tractor troll/ mini truck
option #2
or get all items in small quanity.
my contractor it will make huge diff. and actual qtn is never true in tractor trolly
Please suggest as per your experience.
Tue Dec 15, 2015Post  #1
       There are two solution for problem given by you
1. Take supply from the vehicles which reach directly at your construction site.
2. Unload the material at distance 500' as stated by you and re carriage with tractor.
Compare the rates and adopt which ever is cheap option for you.
In my opinion the 2nd option is better for you.
Thu Dec 17, 2015Post  #2
User the plot for big order then use tractor or mini truck.
2419
what are these 3 types
3912
14515
30*50 west facing 167 sq yards house plan
Last answer on 10/25/2021 9:50:20 PM. by seema tyagi. Forum started by Pasha
54
Best Muslim Wazifa and Dua For Love Problem By Molana Ji 91-7681982445
Last answer on 7/5/2024 1:36:25 AM. Forum started by Miyan Akram JI
51
Last answer on 7/5/2024 1:36:26 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 1:36:27 AM. Forum started by Miyan Akram JI
54
Last answer on 7/5/2024 1:36:28 AM. Forum started by Miyan Akram JI
54
Last answer on 7/5/2024 1:37:08 AM. Forum started by Miyan Akram JI
49
Last answer on 7/5/2024 1:37:09 AM. Forum started by Miyan Akram JI
59
Last answer on 7/5/2024 1:37:10 AM. Forum started by Miyan Akram JI
58
Last answer on 7/5/2024 1:37:11 AM. Forum started by Miyan Akram JI
59
Last answer on 7/5/2024 1:37:12 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 1:37:13 AM. Forum started by Miyan Akram JI
51
Last answer on 7/5/2024 1:37:14 AM. Forum started by Miyan Akram JI
49
61
Last answer on 7/5/2024 1:37:15 AM. Forum started by Miyan Akram JI
50
Last answer on 7/5/2024 1:37:16 AM. Forum started by Miyan Akram JI
49
Last answer on 7/5/2024 1:37:17 AM. Forum started by Miyan Akram JI
50
Last answer on 7/5/2024 1:37:18 AM. Forum started by Miyan Akram JI
3080
RCC roof
1975
Marriage hall construction
2542
Function Hall
4213
11118
2197
2042
Estimate
11131
3077
Steel
3041
use of tmt bar
1648
work turned out by labour
2463
estimate
1767
3011
3609
1945
Cost of Steel construction
2141
READY MIX PLASTER
1867
2229
zero slump concrete
60
60 Tips to Save Water
How to get rid of ants
Ants are most common insects encountered around house, gardens and buildings. Ants become problems when they are found..
Refinishing Hardwood Floors
