Home -> Forums -> Construction -> Bricks -> use of fly ash brick
Tue Oct 18, 2011Total posts : 1
amit
amit
Topic: use of fly ash brick
dear sir,
pl enlighten me on use of flyash brick and its availability and cost effectiveness. is it cheap than normal bricks. i want to use this for my house on 2nd floor construction in delhi. the durabilty can also be informed, thanks
Wed Oct 19, 2011Post  #1
Dear amit
Fly ash bricks are generally used for making curtain and partition walls of the houses/ buildings. Fly ash bricks are used in domestic building in the category of low or middle-income groups mostly have single or two storied dwelling units. Use of fly ash bricks in this type of construction is meant mainly to achieve economy and make profits.
PWD-DELHI Issues Circular for Use of Fly ash Brick
“The PWD-DELHI department Suggested Experimental Use of Fly ash bricks in Site office, Temporary Accommodation/ Boundary walls”
2931
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by Kranap. Forum started by mamta
2708
type of brick
1785
2968
fly ash bricks
3606
1942
Availibility of Fly ash Bricks near Kolkata dumdum airport
Last answer on 2/11/2013 3:12:32 PM. by akmurty1. Forum started by DK
2405
1635
sir i have recently consstructed a house using fly ash based cement for ground f
Last answer on 7/28/2015 11:25:48 PM. by JAI PRAKASH. Forum started by baheer din
2658
2047
question
Last answer on 4/15/2013 12:34:12 PM. by S L Gupta (Civil Engg). Forum started by arpitbedi
2836
Compound Wall Construction
13651
2993
2866
Bricks
3993
4372
Ready Mix Concrete
1702
2457
estimate
1728
Last answer on 11/6/2015 12:41:03 AM. by JAI PRAKASH. Forum started by Techman
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2822
2350
3172
bricks
5660
2014
3238
5136
Use of Solid Concrete Bricks
1625
1341
1846
1480
1797
2968
fly ash bricks
2230
1724
FLY ASH BRICKS
FLY ASH BRICKS
CONCRETE
Hard
Skylight
Types of Cement
