Which are various types of door viewers for houses? The Mini Scope door viewer is a unique 200 degree peephole that is designed to fit thin doors.
| Digital Door Viewers To keep watch on every visitor to your home and maintain records of undesirable persons, install door viewer at the en.. |
Which are various types of alarms used for the security of the house? When the alarm is triggered by one of the alarm components, an outside bell or siren is activated.This alarm will undo.. |
What are the various accessories recommended for Aluminium doors? Various accessories for Aluminium doors :Door Handles,Door Fasteners,Door Viewers.... |
What are various types of panel doors? Single panel, Double Panel, Three Panel, Six Panel doors........ |
What are various types of screws used in windows? Various types of screws used in windows are mentioned below:
Chrome plated brass,Stainless Steel,G.I Screws
What are various types of plywood available for wooden doors? Commercial plywood has commercial layer on faces. Two types- Phenols bonded and Urea bonded.
Which are various types of marble for flooring ? Marble shall be hard , sound, dense and homogeneous in texture with Crysta line texture as far as possible.
