Sun Jun 14, 2009 | Post #1 | Gunjan Utraja
Join date: Dec 2007 | Dear Zoi, Can you upload some pics of the area where you see the cracks so we could access the damage?
Mon Jun 15, 2009 | Post #2 | ZOI
wall crk right n left 2no wall pe hai right pe zada hai humne us mei plaster of paris bhi dala tha bt ab wo phir se dikhne lga hai aur hmri jo piche wali wall hain yani k bahr wli un pe plaster nhi hua hai to plx can u tell me k wo crk kse khtm ho ga? | |
Mon Jun 15, 2009 | Post #3 | ZOI
Join date: May 2009 | wse mei try krn gi k pix upld kr dn bt plx ap ase hi agr bta ske to bta den!! | |
Mon Jun 15, 2009 | Post #4 | ZOI
ye mre room ki wall hai aur ye wo crk hai.. | |
Mon Jun 15, 2009 | Post #5 | ZOI
Mon Jun 15, 2009 | Post #6 | ZOI
crackk | |
Mon Jun 15, 2009 | Post #7 | ZOI
again | |
Mon Jun 15, 2009 | Post #10 | Gunjan Utraja
Join date: Dec 2007 | Dear Zoi, These seems like Surface cracks to me.
Please go through the article to see how to correct this problem.
Thx
Wed Jun 17, 2009 | Post #11 | ZOI
Join date: May 2009 | mre room ki wall mei crack hai agr ap koi choti se b tip bta do k wo crack kese hide ho skta hai to plzzz ap mjhe kch bta do plzzzz plzzzz | |
Wed Jun 17, 2009 | Post #12 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Post subject: How to repair wall cracks
You are facing the problem of cracks in the walls of your house. After seeing the pictures sent by you I reached at the conclusion that foundation of walls of your house is settled. Follow these remedies for cracks problem:
1. Protect foundation from rainwater and drain water. For this, construct plinth protection with all the walls. If you have already constructed the plinth protection than I thought it might be damaged and needs proper repair so that water may not enter in the foundation. 2. Hire good mason and do the repairing of the cracked wall as described below. Remove broken bricks Before doing any repair of cracks, make sure that the cracks are stabilized and are not widening further. Remove broken bricks by scratching cement mortar from the joints gently. Prepare the surface All loose material should be cleaned from the portion by brushing and washing. Wet the surface 24 hours before application of new bricks & plaster.
Fix new bricks thoroughly Lay fresh cement mortar with coarse sand in 1:4 and fix new bricks. Fill all joints around bricks with mortar tightly with the help of iron tools. Do curing and finishing The repaired surface should be kept moist up to 7 days. When surface is dry, it should be finished according to adjoining area.
If you have any further query please call me at 09354908601
Questions (39) | |
2711 views | 1 answers | Last answer on 9/13/2009 11:35:22 AM. by Priti Arora. Forum started by srinivasan | 2897 views | 1 answers | Last answer on 12/31/2020 2:07:59 AM. by Karan. Forum started by tkalaiva | 2486 views | 1 answers | Last answer on 12/26/2011 7:13:39 PM. by S L Gupta (Civil Engg). Forum started by S. Kumar |
| 2437 views | 3 answers | Last answer on 7/14/2014 2:25:04 PM. by S L Gupta (Civil Engg). Forum started by Srinivas | 2800 views | 2 answers | Last answer on 12/20/2021 10:08:04 AM. by Sharath Kurva. Forum started by Sharath Kurva | 2338 views | 2 answers | Last answer on 7/14/2014 2:27:15 PM. by S L Gupta (Civil Engg). Forum started by Srinivas | 2730 views | 1 answers | Last answer on 4/8/2011 10:52:47 AM. by Nikita. Forum started by amartharaj | 3380 views | 1 answers | Last answer on 1/26/2022 2:08:59 AM. by S L Gupta (Civil Engg). Forum started by Amar | 4137 views | 2 answers | Last answer on 7/24/2021 12:31:40 PM. by Girish. Forum started by Rajan | 2334 views | 3 answers | Last answer on 2/4/2015 11:35:37 AM. by S L Gupta (Civil Engg). Forum started by Arun | 2502 views | 1 answers | Last answer on 3/20/2012 2:39:36 PM. by S L Gupta (Civil Engg). Forum started by muqamil | 2716 views | 2 answers | Last answer on 2/23/2011 9:05:33 PM. by Muralidhar. Forum started by Muralidhar | 2997 views | 1 answers | Last answer on 5/19/2014 12:07:41 PM. by S L Gupta (Civil Engg). Forum started by sanjeev kumar | 2709 views | 4 answers | Last answer on 1/1/2021 2:45:02 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh | 2580 views | 1 answers | Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell | 2924 views | 1 answers | Last answer on 11/8/2011 11:00:36 AM. by S L Gupta (Civil Engg). Forum started by timm todd | 2705 views | 1 answers | Last answer on 7/3/2012 12:04:18 AM. by Swati Satija. Forum started by vivek | 3387 views | 5 answers | Last answer on 12/12/2012 2:44:23 PM. by clarasmithh001. Forum started by shabbir ali | 1943 views | 1 answers | Last answer on 1/16/2015 6:11:29 PM. by JAI PRAKASH. Forum started by Bharat Kumar | 10 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
