wall plastering
wall plastering
Sun Jun 05, 2016
prasanna
Topic: wall plastering
The space inbetween two walls is only half feet ..but i want to do plastering in that wall as water leaks through that....is there a way out to plaster wall which has narrow gaps.?
regards
Prasanna
2198
Painting interior walls
Last answer on 7/10/2020 3:18:52 AM. by
K. Basu
1399
crack on wall plaster by gypsum
Last answer on 11/22/2016 1:25:44 PM. by
Rizwan
7203
Alternative to river sand for wall plastering jobs
Last answer on 1/7/2011 3:36:01 PM. by
jaydeep
S. Krishnamoorthy
4594
time for paint and wall putty
Last answer on 1/5/2022 12:42:49 AM. by
Last answer on 11/8/2011 11:00:36 AM. by
timm todd
1887
wall putty
Last answer on 7/3/2020 11:12:22 PM. by
ARVIND GOYAL
8802
Last answer on 1/21/2021 1:04:07 AM. by
karthik
Rahul
3978
Last answer on 7/3/2020 11:38:18 PM. Forum started by
rajeev
6994
Last answer on 11/8/2017 2:30:27 AM. by
Rajesh
3368
Last answer on 12/12/2012 2:44:23 PM. by
clarasmithh001
shabbir ali
949
SIR,I have made new home and i am staying there for last two months. RCC ground
Last answer on 9/7/2018 1:08:09 AM. by
kajal dutta
2142
Last answer on 1/1/2016 12:06:36 PM. by
Prasad
Prasad
1739
What preliminary jobs should be done before painting a cemented wall (plastered wall)?
Last answer on 3/16/2021 5:08:59 AM. by
JAYANT VERMA
2232
about construction
simran
4177
Selection of cement ..
PRAVEEN G
2519
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by
kamlesh
3657
wals
shabbir ali
2514
2071
Last answer on 8/5/2015 4:33:46 AM. by
Rakeeb Rathor
3772
Pandu
9871
nasad
2659
Sreedhar
4612
ani
4129
Anamika
2843
lio
5196
ringwang
R.Roy
4948
MANISH
3636
Arvind Bhaskar
4047
premkumarlen
1843
carmenjames
r.n.misra
2780
Sharath Kurva
Sharath Kurva
2596
gk
Adriano Peres
vamsi
2445
nuksung
2625
dayal
1796
TUNDE
3591
ragha
6228
suba
Plastering
Which type of wall plastering is recommended for protection from the cracks?
To avoid cracks, Earthen Plastering is applied. Clay in Earthen Plasters is Hygroscopic (water absorbing). Earthen wal..
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
