Home -> Forums -> Construction -> Plastic or Acrylic Emulsion Paint -> wall putty
wall putty
Mon Oct 05, 2015Total posts : 2
ARVIND GOYAL
ARVIND GOYAL
Topic: wall putty
Two coats of wall putty and then single coat primer on newly constructed  walls (plastered).
Is it a right option ?
for exterior walls what should i do ?
Mon Oct 05, 2015Post  #1
Dear Goyal
      Completing the wall putty rub the wall surface with sand paper.after this repeat the process. Clean the surface and do the priming coat.
For external do priming on plaster before paint.
Mon Oct 05, 2015Post  #2
do the same.
Plastic or Acrylic Emulsion Paint -Construction Questions (19)
4627
time for paint and wall putty
3084
2212
Painting interior walls
4503
Wall Putty ,primer and paint
2992
9541
Wall Putty and primer
2849
I want tips of procedure of water primer on wall putty. When the water primer sh
Last answer on 7/8/2010 2:03:40 PM. by S L Gupta (Civil Engg). Forum started by Arup Ray
3284
Wall Putty on exterior wall
wall putty
Last answer on 1/2/2021 5:22:50 AM. by leelindsey. Forum started by paresh
1892
Wall Putty
Last answer on 3/11/2014 2:11:56 PM. by Abhishek Garg (Builder & Engineer). Forum started by Purvi Panchal
2187
Exterior wall putty
Last answer on 1/17/2014 11:53:01 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
8880
10934
Lappam vs Wall Putty
2519
1582
Recently I have purchased a flat. But I have no plan to paint interior walls rig
Last answer on 6/8/2016 12:54:24 PM. by S L Gupta (Civil Engg). Forum started by K. Basu
Electrical fitting - Switches and sockets
Last answer on 12/12/2012 1:07:05 PM. by Vijay. Forum started by Vijay
3380
Recurring Cracks
537
2015
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Last answer on 5/5/2014 2:31:18 PM. by PR Jawahar. Forum started by Anurag
Wall
Wall painting design
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
