Home -> Forums -> Construction -> Start Construction -> wall putty
wall putty
Mon Sep 01, 2014Total posts : 2
Topic: wall putty
hi
i have newly plaster on wall. can i do putty work or we need to dry wall  before doing putty work.
is there any solution that we can do putty immediately after plasterig  and wall dont have crack .
Tue Sep 02, 2014Post  #1
Dear Paresh
Tips for Surface Preparation
  • Allow newly plastered surface to mature for a period of at least 6 months before painting.
  • Rectify existing surface problems such as dampness, cracks etc. before actual painting process.
  • Check for hand prints, greasy fingerprints, algae as well as dirt and stained marks.
  • Use a scraper, putty knife or scrub brush to remove any dirt, grease, rust, or flaking.
  • Fill in the holes, cracks and joints with plaster.
  • Clean and dry the surface.
  • Make sure the area to be painted is well ventilated as well as free of dust.
  • As far as possible, don’t paint under much humid conditions.
If you have want work earlier than apply alkali resistance cement primer(IS;109-1993)
Wed Nov 04, 2020Post  #2
In simple terms, wall putty is basically a white cement based fine powder that is created into a smooth mixture and applied to the walls before painting.
4627
time for paint and wall putty
3084
2212
Painting interior walls
4503
Wall Putty ,primer and paint
2991
9541
Wall Putty and primer
2849
I want tips of procedure of water primer on wall putty. When the water primer sh
Last answer on 7/8/2010 2:03:40 PM. by S L Gupta (Civil Engg). Forum started by Arup Ray
3284
Wall Putty on exterior wall
1892
Wall Putty
Last answer on 3/11/2014 2:11:56 PM. by Abhishek Garg (Builder & Engineer). Forum started by Purvi Panchal
2187
Exterior wall putty
Last answer on 1/17/2014 11:53:01 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
8880
1896
wall putty
Last answer on 7/3/2020 11:12:22 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
10934
Lappam vs Wall Putty
2519
1582
Recently I have purchased a flat. But I have no plan to paint interior walls rig
Last answer on 6/8/2016 12:54:24 PM. by S L Gupta (Civil Engg). Forum started by K. Basu
Electrical fitting - Switches and sockets
Last answer on 12/12/2012 1:07:05 PM. by Vijay. Forum started by Vijay
3380
Recurring Cracks
536
2015
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Last answer on 5/5/2014 2:31:18 PM. by PR Jawahar. Forum started by Anurag
3310
Wall
Wall painting design
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
