Home -> Forums -> Construction -> Start Construction -> what is the wall thickness for a 9000 sqft building
Sat Jan 09, 2010Total posts : 1
shankar
shankar
Topic: what is the wall thickness for a 9000 sqft building
What would be the wall thickness for a 9000 sqft building? Basement plus 2 floors.
Tue Jan 12, 2010Post  #1
Post subject: Reply- What is the wall
Dear Shankar,
The thickness of walls is designed according to loading condition. For load bearing walls, thickness should not be less than 9’’.
And in case of frame structure building, the thickness of walls may be 4.5’’ or 9” according to structure need.
S.L. Gupta (Civil Engg.{Retd.})
3656
Wall Thickness
2862
8321
7257
3273
11559
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
2123
Wall Thickness
3601
How we Calculate Construction Cost
Last answer on 10/21/2014 10:35:00 PM. by JAI PRAKASH. Forum started by JEETU KALANI
1594
i want to build 300 sqft houuse want a elevation model house
Last answer on 7/3/2020 11:49:54 PM. by S L Gupta (Civil Engg). Forum started by vimaladevi
2936
Right price or not .. Kindly advise
Last answer on 7/3/2020 9:28:23 PM. by S L Gupta (Civil Engg). Forum started by everfor
2694
2211
4128
6254
2458
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
11829
cost of rbc and rcc slab
2821
building a house
3002
House Estimation Breakdown
1958
i have a plot in Aurangabad and am interested to constuct the Residential appart
Last answer on 1/18/2011 5:32:32 PM. Forum started by Gurmeet chhabra
3310
Orientation
Orientation of Building
Canvas
Canvas Wall Art
Wall
Wall Decor
