Tue Feb 19, 2013Total posts : 2
DK
DK
Topic: What is the wall (interior wall and exterior wall) thickness of a regular house?
What is the wall (interior wall and exterior wall) thickness of a regular house?Thanks for answer,DK.
Tue Feb 19, 2013Post  #1
Dear DK
          There are interior and exterior wall but there are walls also deferenciate according to loading condition i.e. load bearing wall and non load bearing walls. When load of roof is given on the walls than there design is as load bearing walls, but in case frame structure, when load is given on columns/ pillars than we construct non load bearing walls. In case walls are to take load of roof than external and internal walls are  not less than 9'' thickness. In frame structure the external wall should be 9'' thick and internal walls may be 9'' or 4.5'' thick.
Tue Feb 19, 2013Post  #2
DK
DK
Post subject: Thanks
Highly appreciated for details answer Mr. Gupta.
Thanks again,
DK.
Wall Thickness
2616
Exterior Walls
3713
exterior walls
2338
8321
7256
3469
Cost of concrete walls
2729
3283
Wall Putty on exterior wall
2565
2212
Painting interior walls
1692
4128
35861
wall paint color combination
3080
2675
Last answer on 1/10/2022 11:40:17 PM. by seema tyagi. Forum started by vaishali
2592
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
2458
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
1494
I am planning for a two storied 2BHK house in my village. I am thinking of exter
Last answer on 7/3/2020 10:33:53 PM. by S L Gupta (Civil Engg). Forum started by Sumathi Iyengar
Paint
Painting
Wall
Wall Accents for Your Rooms
Wall
Wall Decor
Canvas
Canvas Wall Art
Home Decorating Tips
Your home is a place where you live, dont make it a workplace, dont mess up. Decorate your home in unique style. Use w..
