Layout and House Plans
want a appropriate map for ist floor extention
Thu Jun 19, 2014
dr hemant isngh
Topic: want a appropriate map for ist floor extention
hello sir/mam
i am attaching my already constructed house plan..
i have a plot size of 30widthx50depth south facing.30widthx24depth is
available in front
side
in back side 2 room,1 hall,1 lat bath and
stairs already made.now i want to make 2 room kitchen and 1 lat bath,
with proper ventilation and vastu.kindly guide me.
available depth of 24 including 3 feet extra floor apart from depth of plot.
home map.ppt on Thu Jun 19, 2014,&n
Thu Jun 19, 2014
megha
Post subject: Solution
I want exact sizes of your room to fit your hall in new position.
Also
I wanted to ask whether it is permissible as per legal authorities to construct in your front open space.
Thu Jun 19, 2014
megha
Post subject: Some Idea of renovation
See attached. See modification. Max. Hall width 18 ft. it is more than enough. Even though if u want to modify u r free to do so.
home map.ppt Thu Jun 19, 2014,&n
1767
Last answer on 10/26/2015 11:57:26 AM. by
sigamani
15781
Last answer on 12/8/2014 6:14:14 PM. by
Deep Shrestha
Deep Shrestha
5334
Wanted to get House Map for 28 * 28* Sq. Feet Plot
Last answer on 5/28/2014 2:10:37 PM. by
Parshant
1763
My plot in city paonta sahib HP 17302939*45 ft I want's to a good vastu shastra
Last answer on 10/14/2021 8:51:31 AM. by
Anil Kumar
2203
my house is on ist floor,but it gets too much heated due to terrace , what to do
Last answer on 10/2/2009 10:44:20 PM. by
Priti Arora
salim noorani
1964
good evining and good day my polot size 31*72 feet plz need me floor map
Last answer on 6/9/2015 11:09:22 AM. by
Muhammad Iqbal
2648
Please suggest house Map for ground floor plot Size 10x22.5 feet
Last answer on 8/4/2016 5:21:11 PM. Forum started by
Gopal Upadhyay
1860
please share a 23.5*60 map groud floor full hall and residence at first floor ea
Last answer on 5/27/2016 6:20:06 PM. by
suthardr
8582
Last answer on 12/25/2013 2:07:19 PM. by
arunkrishna kannambadi
2889
Hi I m pratyash Kumar distt deoria utter Pradesh sar may plot area 882 18×49 roa
Last answer on 8/27/2014 2:54:02 PM. by
sweety
Pratyash Kumar
19315
40 feet broad and 25 feet depth and is north facing plot please tell me the map
Last answer on 10/30/2014 10:06:26 AM. by
amy ram
3300
Last answer on 8/11/2017 2:13:58 AM. by
HOME
Mitesh
1481
Sir I hv a plot 21feet*42feet facing west please provide map for single floor
Last answer on 1/30/2017 12:24:13 PM. by
S pd
1391
I have poor 23.5x70 it is east side but opposite only road so I want main door
Last answer on 11/6/2017 2:05:30 AM. by
goutam
1333
hello,Can you please provide me the map plan for 20 by 50 mtr plot for making re
Last answer on 7/3/2020 11:14:59 PM. by
Ravi Yadav
I am staying in ground floor flats with extention in south in southeast corner w
Last answer on 7/2/2020 9:46:11 PM. Forum started by
prakash
2587
flooring
Last answer on 5/31/2012 7:13:24 PM. by
watson
pallubc2
1949
Last answer on 7/9/2011 9:20:20 PM. by
prasadtvp
Salome Dagnachew
15360
2nd floor construction
Last answer on 7/3/2020 9:53:01 PM. by
bhuvaneshwaran bn
manjuks
2691
Raj
2188
Amutha
2184
vanramr
2791
raghu
4520
Nitien Parmar
suryarao p
1890
santosh
2284
Deepak Giri
2265
ajay sharma
2766
u v sudhakar
3464
ramana
2356
srinivas kamsali
1967
tanaya483
2242
ramanapeddu
3595
SRIKANTH.S
2324
HIRA SINGH
2792
Alexander Graf
Mohiuddin
1548
uma shankar
2114
mohammedbasha
Refinishing Hardwood Floors
Checklists for flooring
Vinyl Flooring
Drawing Room Flooring
