Home -> Forums -> Construction -> Start Construction -> want aplot layout
want aplot layout
Thu Sep 25, 2014Total posts : 1
vipantiwari
vipantiwari
Topic: want aplot layout
Dear sir i wants a layout of plot whose size 3150squarefeet whose front width  is56&back width is 49 depth is 60 metres.
Thu Sep 25, 2014Post  #1
After
completion
of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
3802
Orientation of Building
Last answer on 8/6/2010 2:09:05 PM. by narayan. Forum started by pooja
2028
Sir i wants a layout of polt whose size is 3150 squarefeet whose front width is
Last answer on 9/26/2014 11:24:08 AM. by seema tyagi. Forum started by vipantiwari
2364
1940
2166
helloI wanted to know how much should I be charging for a client who just wants
Last answer on 8/9/2013 10:02:39 PM. by Purvi Panchal. Forum started by sruti
5335
I wants windows and door design
Last answer on 7/3/2020 11:34:08 PM. by S L Gupta (Civil Engg). Forum started by Prahlad Kumawat
2264
Last answer on 7/4/2016 5:42:09 PM. by S L Gupta (Civil Engg). Forum started by Aniket
3441
Last answer on 10/8/2021 12:49:42 AM. by Navneet Jharia. Forum started by vgshekar1
2927
Skylights
Last answer on 12/31/2020 2:07:37 AM. by Rajan. Forum started by hemapradeep
4702
wants detailing of modilar kitchen size of otta 13' x 2' in l shape
Last answer on 2/21/2013 11:53:31 AM. by johnbritto. Forum started by vikas bahadure
2602
i wanted the design for the pillar but i dont get it
Last answer on 7/4/2020 2:44:41 AM. by paresh jadavani. Forum started by florinda dsouza
3185
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
1950
I NEED LAYOUT FOR SOHP STIRCASE ,LOCKER ALMARAS ,OUR SHOE IS EAST FACING DUPLEX
Last answer on 8/29/2010 4:06:02 PM. Forum started by ANOOP JAIN
2664
procedure of building layout detail
Last answer on 3/15/2011 6:11:55 PM. by Mohini Sharma. Forum started by kanwer sajjad
2615
it would be great if you could send the layout of this house
Last answer on 10/27/2010 6:05:42 PM. by Lydia Jenifer. Forum started by Lydia Jenifer
2837
I need a detailed layout of above picture.
Last answer on 11/13/2021 12:05:33 AM. Forum started by sachinjoshi69
1891
plz send me layout of duplex flate of area 1300sqft
Last answer on 1/31/2011 12:28:10 AM. Forum started by ajeet kumar
2491
1883
3312
2236
2313
2061
Kitchen Ideas
Make your kitchen both friendly and well-organized with these creative decorating ideas. Kitchen is a one of the most ..
Bedroom Design
Bedroom is the only heaven where prevails recreation and relaxation after weary day. This article draws upon general f..
Iron
Iron Sheet Roofing
ACC
ACC Sheet Roofing
Kitchen Decoration
