Home -> Forums -> Construction -> Start Construction -> water proofing
water proofing
Tue Sep 30, 2014Total posts : 8
sunil kumar
sunil kumar
Topic: water proofing
what is the proccess of waterproofing
Tue Sep 30, 2014Post  #1
There are different methods available.
Do you need it for terris or walls?
Wed Feb 26, 2020Post  #2
          Thanks for visiting the site.
Thu Mar 19, 2020Post  #3
Thu May 14, 2020Post  #4
Waterproofing is the process of making an object or structure waterproof or water-resistant so that it remains relatively unaffected by water or resisting the ingress of water under specified conditions. Such items may be used in wet environments or underwater to specified depths.
Water-resistant and waterproof often refer to penetration of water in its liquid state and possibly under pressure, whereas damp proof refers to resistance to humidity or dampness. Permeation of water vapour through a material or structure is reported as a moisture vapor transmission rate.
The hulls of boats and ships were once waterproofed by applying tar or pitch. Modern items may be waterproofed by applying water-repellent coatings or by sealing seams with gaskets or o-rings.
Waterproofing is used in reference to building structures, watercraft, canvas, clothing, electronic devices and paper packaging.
Tue Jun 16, 2020Post  #5
Tue Oct 13, 2020Post  #6
Mon Oct 19, 2020Post  #7
Wed Nov 04, 2020Post  #8
2237
2240
2771
3170
APP membrane
2347
lift pit water proofing
3836
ROOF WATER PROOFING / TANKING
2902
Terrace water proofing
2323
Water proofing method
2835
950
Sir, I have constructed 12000 lit concrete sump. Plastering done with cement,san
Last answer on 7/3/2020 9:23:58 PM. Forum started by sunder
2408
3972
water proofing of water tank
1855
Bathroom-water proofing and tiles
Last answer on 12/8/2014 10:03:14 PM. by JAI PRAKASH. Forum started by bhr2014
2385
1708
Need help about painting and wall water proofing
Last answer on 3/11/2014 3:08:54 PM. by Ahmed. Forum started by vamsi
1825
Last answer on 3/13/2015 1:44:42 AM. by JAI PRAKASH. Forum started by ringwang
2305
2071
Water proofing west side facing wall
Last answer on 4/22/2013 12:00:58 PM. by S L Gupta (Civil Engg). Forum started by Vineet b
1778
Water Proofing for Basement
Last answer on 5/5/2013 10:44:53 PM. by Abhishek Garg (Builder & Engineer). Forum started by RUSJIM
2479
3302
3318
4449
4018
2243
2722
4233
5204
2392
2318
2021
2463
2140
3213
2070
12538
2185
2029
2748
Basement Design Ideas
Damp
Damp Proofing
Protect
Preventive
Fire
Guideline for laying DPC
Earthquake
Electric
Electric Shock Proof Home
