Ground work
water proofing of water tank
Wed May 21, 2014
Topic: water proofing of water tank
hi,
I am facing problem to making underground water tank as water is coming continuously. we have constructed 4" outer brick wall except joining joint of bottom brick wall from all four side so that all water only come through open joint of bottom of wall .like this way we have constucted wall up to desire level.
Now problem is as we go to drain all water through pump for joining that remaining open joint of wall, water is continuously coming and we are unable to do plaster or joint that open joint
is there any solution for this?
Thu May 22, 2014
Post subject: Please go through
http://durabuildcare.com/waterproofing-underground-water-tank.php
http://www.waterproofingindia.net/waterproofing-systems.html
http://www.isomat.eu/Waterproofing-of-watertanks-and-reservoirs-made-of-concrete.html
Thu May 14, 2020
One of the most important issues that builders confront with while constructing concrete water reservoirs is waterproofing.In the case of an underground reservoir, the waterproofing layer must: Ensure that there is neither leakage of water from the reservoir nor any ingress of water from the surrounding soil.
5055
mohammed sadhiq ali
2232
Last answer on 1/10/2016 8:50:43 PM. by
venkatesh
2767
Last answer on 9/21/2016 12:04:43 AM. by
Pawan kumawat
Satvinder kaur
2236
Last answer on 12/19/2013 10:54:10 AM. by
MOHD WAKEEL
MOHD WAKEEL
3119
Last answer on 9/19/2014 9:38:22 AM. by
Unoara Design Hub
nishant shah
2187
Last answer on 1/19/2022 6:10:39 AM. by
HANUMAN
1728
Last answer on 11/14/2015 12:33:03 AM. by
kk
1934
Last answer on 11/14/2015 12:31:59 AM. by
kk
2483
Last answer on 6/3/2021 3:08:10 AM. by
Shreevardhan
2375
water tank
Last answer on 1/12/2021 1:31:33 AM. by
vinod jangid
6272
Water Tank Quality
Last answer on 7/22/2021 5:19:42 PM. by
George Turner
Raman Mittal
Last answer on 11/22/2020 8:39:03 PM. by
manjuks
3163
APP membrane
Last answer on 4/7/2021 11:05:28 PM. by
upsersv2e
chrome
1844
Last answer on 2/16/2017 2:10:10 PM. by
MRINAL SENGUPTA
7232
2 lakh litre water tank
Last answer on 5/17/2016 1:30:52 PM. by
Shardul
1887
water tank motor capacity
Last answer on 3/28/2015 6:29:22 PM. by
lift pit water proofing
Last answer on 11/5/2012 12:01:57 PM. by
anand
3828
ROOF WATER PROOFING / TANKING
Last answer on 11/17/2009 10:47:13 AM. by
Girish
Girish
2995
Karan
8160
software
Vaasku
sco4666
sagar suryawanshi
2730
Manish Singh
1833
lanterns
ARVIND GOYAL
3134
false ceiling
sabita laskar
2245
about construction
simran
1786
lowz
4154
Cement Coba
Last answer on 12/21/2021 8:15:49 AM. by
Prasenjit
3076
Water Harvesting System
sunny420
1676
Robert
1758
water tank
rodmotall4
sadanand
2058
sumit
1760
jitendra kumar
1634
Pool construction cost
Erling
Shardul
1994
sanyindias
2738
Regarding roof beam
Amit Kumar
Fire Stair case
mvxmanazxmfsm
tejas
2645
MOHD WAKEEL
2371
super structure
anil kumar
Vastu for Water Tank
60 Tips to Save Water
Damp Proofing
Water for Construction
