Home -> Forums -> Construction -> Plumbing -> water softner
water softner
Thu Sep 06, 2012Total posts : 1
pallubc2
pallubc2
Topic: water softner
Hello All,
I have borewell water and corporation water connection to my under construction house. I want to know whether to put different tanks or use a water softner and mix both the water. And also how much would a water softner cost, is it feasible to have one, what would be the maintanance cost of it.
Thanks in advance,
Pallavi
Fri Sep 07, 2012Post  #1
Dear Pallubc
       The water for construction should be tested as per IS3025--1986specially in the frame work building or where RCC is to be used in construction of building. The lab test can give the treatment method and in my view it is not fullproof method use any softner on you own wish. The bore wellwater found some time salty and need treatment but you will be surprised at some places corrporation water is not 100% fit for concrete work. So for betterment the water should be tested.Read the below artical
How to test water and what should be tested
It is recommended that the water is tested through a certified lab. The water should confirm the standard IS: 3025-1986 which is briefly described below.
Limit of Acidity: To neutralize 200 ml sample of water, use phenolphthalein as an indicator. It does not require more than 2 ml 0.1 normal NAOH.
Limit of Alkalinity: To neutralize 200 ml sample of water, use methyl oil as an indicator, it does not require more than 10 ml 0.1 normal HCL
Limit of Solids
Organic: 200 Mg per liter
Inorganic: 3000. Mg per liter
Sulphate: 400 mg per liter
Chloride: 500 mg per liter for RCC work and 2000 mg per liter for concrete not containing steel.
Suspended matter: 2000 mg per liter. To get more about water read the link below.
http://www.gharexpert.com/articles/Water-1837/Water-Construction_0.aspx
1726
what is the cost and feasibility of installing a water softner for 4 members
Last answer on 10/16/2014 12:52:21 AM. by JAI PRAKASH. Forum started by neelam rathi
1550
what is the cost and feasibility of installing a water softner for a family of 4
Last answer on 10/16/2014 12:52:29 AM. by JAI PRAKASH. Forum started by neelam rathi
3370
2180
pile work
5055
6414
3968
water proofing of water tank
2388
6272
Water Tank Quality
2792
Last answer on 7/3/2020 11:53:31 PM. Forum started by mamta
2072
Dear Sir,We get water supply from city corporation
Last answer on 5/27/2012 8:33:01 PM. by Raghavendra. Forum started by Raghavendra
3803
2766
1620
where is water bouring
Last answer on 12/30/2010 9:07:12 PM. by S L Gupta (Civil Engg). Forum started by king jain
3499
3119
2515
water is south east corner
Last answer on 3/15/2013 10:51:48 AM. by Ravi. Forum started by rahul
2833
how to make footing and column for g 2 building on water well
Last answer on 4/1/2013 7:09:40 AM. by Arun. Forum started by Arun
6272
Water Tank Quality
3114
Hot Water Tank
2915
Sand in Water
3380
Diverters for Bathroom
2563
2149
40519
2083
GI pipe Vs CPVC pipeline
2931
1755
2081
Toilets
1990
Wall mounted cummod vs normal
5055
2775
2388
1857
3076
Swimming pool
2682
commode type and flush type
4195
to shut off water to house
60
60 Tips to Save Water
Vastu for Water Tank
Water for Construction
Rain
Rain Water Harvesting
Preventive
General
