Ground work
water tank
water tank
Mon Apr 06, 2015
sadanand
Topic: water tank
thanks sir , but pls tell me how much rcc thickness is suitable for side soil and
inside water pressure tobe ahndled . and is it also reqiure rcc at base of tank
Mon Apr 06, 2015
The thickness of RCC wall would be 8'' and base thickness should be 6'' to 8'' thick,
Ground work-Construction Questions (40)
3103
Last answer on 9/19/2014 9:38:22 AM. by
Unoara Design Hub
nishant shah
2359
water tank
Last answer on 1/12/2021 1:31:33 AM. by
vinod jangid
2464
Last answer on 6/3/2021 3:08:10 AM. by
Shreevardhan
1713
Last answer on 11/14/2015 12:33:03 AM. by
kk
1918
Last answer on 11/14/2015 12:31:59 AM. by
kk
2168
Last answer on 1/19/2022 6:10:39 AM. by
HANUMAN
6261
Water Tank Quality
Last answer on 7/22/2021 5:19:42 PM. by
George Turner
Raman Mittal
1831
Last answer on 2/16/2017 2:10:10 PM. by
MRINAL SENGUPTA
2044
sumit
1760
Last answer on 7/4/2016 5:30:43 PM. by
upendra
2944
Last answer on 9/1/2015 2:51:50 AM. by
sher singh daulta
2011
Last answer on 4/25/2015 2:17:43 AM. by
sudha
2322
Last answer on 2/4/2015 11:35:37 AM. by
Arun
2209
water supply
Last answer on 6/18/2014 11:46:36 AM. by
simran
2620
Last answer on 1/20/2021 8:48:02 PM. Forum started by
drlpsingh
5189
Last answer on 9/17/2012 4:28:54 PM. Forum started by
Amatuer
2441
Last answer on 10/3/2012 9:58:30 PM. by
JASBIR MALHOTRA
2105
Last answer on 9/13/2010 4:33:09 PM. Forum started by
Asha Khaitan
1874
water tank motor capacity
Last answer on 3/28/2015 6:29:22 PM. by
Last answer on 4/11/2017 11:10:57 AM. by
2969
Karan
8103
software
Vaasku
sco4666
sagar suryawanshi
2721
Manish Singh
1823
lanterns
ARVIND GOYAL
3117
false ceiling
sabita laskar
2232
about construction
simran
1771
lowz
4143
Cement Coba
Last answer on 12/21/2021 8:15:49 AM. by
Prasenjit
3065
Water Harvesting System
sunny420
1653
Robert
1739
water tank
rodmotall4
sadanand
2044
sumit
1747
jitendra kumar
1624
Pool construction cost
Erling
Shardul
1973
sanyindias
2724
Regarding roof beam
Amit Kumar
2048
Fire Stair case
mvxmanazxmfsm
tejas
2633
MOHD WAKEEL
2355
super structure
anil kumar
Vastu for Water Tank
Reasons of dampness
60 Tips to Save Water
Water for Construction
Sewerage & Plumbing System
Rain Water Harvesting
