Home -> Forums -> Construction -> Dampness -> water treatment for walls
Wed Apr 27, 2011Total posts : 3
gajender pathak
gajender pathak
Topic: water treatment for walls
My drawing room size is 9 * 13 ft
one 13 ft wall - door at the rightmost side.
both the 13 ft walls has extreme dampness problem. We are looking for tiles on each wall till 4 ft height from the ground. But I am not convinced with this solution as I can not do the good interior then. Please suggest me the best solution. I want to place the LED TV on second 13 ft wall (opposite to gate)
Please suggest am I doing the right choice.
Thanks and Regards
Gajender Pathak
Thu Apr 28, 2011Post  #1
Dear Gajender
                The right solution is to find out the cause of dampness rater than to hide the dampness. The dampness in the walls are may be any leakage in pipes with walls or leakage in waste water pipes/ sewer line or not laying proper DPCduring construction or using salty bricks etc. Find out the cause and cure it. some time it is seen that dampness travell upword after fixing the tiles on the wall.
Sun May 01, 2011Post  #2
gajender pathak
gajender pathak
Post subject: Thanks sir
Yes I know the cause . This is due to the manhole at my neighbour's side.
And I have asked for some solution from my neighbour. But he is not doing anything for this.
Please sir suggest me some solution.
Thanks and Regards
Gajender Pathak
Mon May 02, 2011Post  #3
Dear Gajender
         As stated by you that neighbour house man hole creating problem for you. If he is not ready to ractify defect than you should rectify that with your cost because this defect  is harmfull for your building and at later stage it will cost you more.
Dampness-Construction Questions (35)
2764
1933
what is the treatment done on the wall and how? looks good
Last answer on 10/19/2010 4:38:10 PM. Forum started by pratima sood
3967
water proofing of water tank
2129
is that crack making good treatment reliable
Last answer on 7/7/2010 8:53:52 PM. by S L Gupta (Civil Engg). Forum started by antoine vencatasawmy
2144
i need the term related with damp proof and its treatment
Last answer on 8/29/2012 5:01:18 PM. by S L Gupta (Civil Engg). Forum started by abhijeet joshi
2675
Termite Treatment
Last answer on 9/25/2020 2:58:44 AM. by S L Gupta (Civil Engg). Forum started by Hidayath
2613
Grey water recycling treatment system in India
Last answer on 12/31/2020 2:22:50 AM. Forum started by Rajan
2290
Last answer on 1/5/2022 2:14:28 AM. by JAI PRAKASH. Forum started by chethan
1989
Last answer on 4/26/2015 5:52:24 PM. by JAI PRAKASH. Forum started by chethan
1680
Last answer on 4/20/2015 1:18:43 AM. by JAI PRAKASH. Forum started by chethan
1761
Last answer on 4/20/2015 1:20:37 AM. by JAI PRAKASH. Forum started by chethan
2756
Salt water
6580
2430
how to avoid rain water seepage in 4 inch brick wall any suggestion?
Last answer on 5/21/2015 5:29:55 PM. by JAI PRAKASH. Forum started by ashok
2321
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
2498
Protect your Home from Bugs
Last answer on 12/29/2010 2:52:39 PM. by Nikita. Forum started by trimbak
2674
Damp Proofing
Last answer on 12/31/2020 1:53:13 AM. by Mike Perkin. Forum started by VIPIN
3490
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by Girish. Forum started by Rajan
1861
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
1491
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by JAI PRAKASH. Forum started by farofaschafer
2073
2106
2131
Walls are damp in rain
2084
1885
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
1920
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by JAI PRAKASH. Forum started by sandipvora
2762
1926
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by S L Gupta (Civil Engg). Forum started by sunder
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2531
Reasons of dampness
1748
2086
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
Termite Treatment for windows- Precautions and tips to remember
Termites are major wood destroying insects. We must take every precaution while doing any construction. Here are few t..
Water for Construction
Termite
Termite Control
Have you protected your home from termites? Termites destroy household articles and create unhygienic conditions for i..
Damp
Damp Proofing
Protection
Protection against Mosquitoes
A few diseases like Dengue and Chikungunya have resulted in expressions of confusion all around. These diseases are tr..
What are anti-termite chemicals? How to control them?
For Termite Control in existing as well as new buildings, soil treatment with chemical is essential in order to protec..
Window
Window Treatments: Window Blinds for Windows
Know about the different styles of window blinds and add style with window treatments such as blinds, shades, curtains..
Canvas
Canvas Wall Art
