Home -> Forums -> Construction -> Cement Plastering -> waterproofing agents and anti corrossion chemicals
Tue Dec 17, 2013Total posts : 2
MOHD WAKEEL
MOHD WAKEEL
Topic: waterproofing agents and anti corrossion chemicals
dear sir i want to know what are the different water proofing agents available in market and also tell does same water proofing chemical will also serve the purpose of anti corrosion chemicals to the reinforcement.
please also help me to know how this water proofing chemicals shall me mixed in cement to have better protections and also what are the construction stages where this water proofing chemical is must to be used.
Wed Dec 18, 2013Post  #1
Dear Wakeel
            See the link below for water proofing chemicals and the method of application is given on the chemical pack.
http://www.gharexpert.com/articles/Dampness-743/Which-type-chemical-recommended-prot_0.aspx
http://www.gharexpert.com/construction-ideas/dampness.aspx
Thu Dec 19, 2013Post  #2
MOHD WAKEEL
MOHD WAKEEL
Dear Gupta sir really thankful for your precious time to review my query and answer it in minimum possible time.
thank you sir may god bless you
will be stay in touch to you if having some other query.
thanks again
please tell me the procedure of bb.coba for terrace waterproofing and please sug
Last answer on 8/24/2020 10:18:48 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
6466
1881
Is a apartment block anti-vaastu if it has a pond on its south
Last answer on 3/5/2021 2:56:01 PM. by JAI PRAKASH. Forum started by siddhartha
2822
1958
How to best waterproof the walls for monsoon?
Last answer on 6/20/2009 12:40:49 AM. by H S Rathi. Forum started by Karan
3499
water proofing
Last answer on 12/2/2020 2:44:35 AM. by leelindsey. Forum started by sunil kumar
13061
what is IPS type waterproofing
Last answer on 9/23/2021 2:31:50 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
3757
PLEASE TELL ME THE DIFFRENCE BETWEEN B.B.COBA AND IPS TYPE OF WATERPROOFING FOR
Last answer on 7/30/2014 9:22:58 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2499
Protect your Home from Bugs
Last answer on 12/29/2010 2:52:39 PM. by Nikita. Forum started by trimbak
2058
What are anti-termite chemicals? How to control them?
Last answer on 3/26/2012 1:22:51 PM. by Khushboo. Forum started by NEELAM CHETWANI
2873
Types of Cement
2260
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
1955
waterproofing on terrace is mandatory?
Last answer on 5/16/2015 7:42:30 PM. by JAI PRAKASH. Forum started by gaurav
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
4736
2174
Outer Plaster
2319
Water proofing method
2829
2467
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
2929
Plaster
2781
Plaster work
3048
Plastering
1925
2006
PPC and OPC cement
11300
1871
suggest for exterior
7006
9158
1878
OPC and PPC cement
2158
2012
coarse aggregate
1826
Nice
2438
Gypsum Plaster Vs S/C Plaster
2174
Outer Plaster
2997
2735
putty work on walls
2828
2033
For Termite Control in existing as well as new buildings, soil treatment with chemical is essential in order to protec..
Fire
Fire Extinguisher
Fire Extinguisher help avoid accidental fire in the kitchens or homes. It extinguishes not only the fire but saves our..
Tips for Cement Paint
What precautions do we take in order to make the windows termite free?
The presence sign of termites is through tale tubes. Termites travel in these tubes and are supposed to eat away wood ..
Damp
Damp Proofing
Bathroom Safety Tips
Do you want to enjoy real bath? Make sure you are taking dip in a safe bathroom. You need to pay heed to temperature s..
