Home -> Forums -> Construction -> Start Construction -> waterproofing on terrace is mandatory?
Mon Aug 04, 2014Total posts : 3
gaurav
gaurav
Topic: waterproofing on terrace is mandatory?
hello i would like to ask as i have constructed 4floors with stilt parking in delhi.
so i would like to ask is this compulsary to have waterproofing & heat proofing chemical on top as recommended by my architect?
how much it would cost?
Tue Aug 05, 2014Post  #1
Post subject: waterproofing on terrace is mandatory
Hello..! Mr.Gaurav, To protect ,structure of building from different weather conditions,it is recommended to go for   waterproofing & heat proofing on roof top. As compared to cost of building, it costs  much less......So many types of products are available in market with facility of the Applicator also..Regards
Fri May 15, 2015Post  #2
prit123
prit123
Waterproofing of flat terraces is a tricky problem in building construction, mainly because the surfaces are flat.
The most cost-effective method appears to be treating the concrete roof on the same evening of concreting, when it is still not hard set. Thin slurry with one part cement, two part fine grain river sand and ample water to create the flow condition is poured on the top of the freshly cast roof. Then, starting at one end, the masons will work backwards, gently levelling and pressing the slurry into the concrete, filling its micro pores; wiping out the step marks and such other undulations using a square, flat, handled trowel.
Many companies have been promoting methods and corresponding products of their own towards effective terrace finish. Most of them rely upon chemicals, polyurethane coatings and admixtures, hence tend to have a limited life span, though they guarantee the surface until then.
Sat May 16, 2015Post  #3
Yes it is mandatory, costing depends upon the material you select.
3757
PLEASE TELL ME THE DIFFRENCE BETWEEN B.B.COBA AND IPS TYPE OF WATERPROOFING FOR
Last answer on 7/30/2014 9:22:58 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2715
please tell me the procedure of bb.coba for terrace waterproofing and please sug
Last answer on 8/24/2020 10:18:48 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
5170
2340
Waterproofing leaks from terrace
Last answer on 5/15/2015 11:08:13 AM. by prit123. Forum started by island
3910
2894
Terrace water proofing
13059
what is IPS type waterproofing
Last answer on 9/23/2021 2:31:50 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
3499
water proofing
Last answer on 12/2/2020 2:44:35 AM. by leelindsey. Forum started by sunil kumar
1957
How to best waterproof the walls for monsoon?
Last answer on 6/20/2009 12:40:49 AM. by H S Rathi. Forum started by Karan
1750
Terrace
Last answer on 8/5/2013 1:06:35 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2351
4042
How to Apply Ceramic tiles on roof Terrace
Last answer on 12/3/2011 10:27:48 PM. by newtondisc. Forum started by Pooja Panchal
2639
where to keep pooja mandir in living room measuring 17X19sq feet with terrace in
Last answer on 3/24/2012 2:53:23 PM. Forum started by srpatil
2297
3121
1544
Last answer on 1/28/2018 4:51:24 AM. by Er.S.K.Jain. Forum started by S.Nagarajan
1799
2259
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
2466
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
3309
2133
2059
Roof Garden
Tips for Cement Paint
