Sun Aug 19, 2018Total posts : 3
Mohammed Abdul Aaeed
Topic: we have extended rcc slab by 20 inches along the length of a 44 feet beam by usi
we have extended rcc slab by 20 inches along the length of a 44 feet beam by using 10 mm main and 8 mm steel bars as reinforcement. The beam was chiseled/chipped and the new 10 mm bars are tied to the old bars of beam @5 inch c/c. providing alternate L hook connection with the beam and alternate straight bars. The distribution steel is 8 mm. The extended slab DO NOT have an extended beam underneath. The 10 mm bars were welded also. Can i construct a 4" thick wall on the edge of the extended slab up to full floor height(taking the extended slab into room space)??? the thickness of slab is 4-5 inches...
Sun Aug 19, 2018Post  #1
       There are two option. One is to test the slab by loading it with earth filled bags on the edge of newly laid slab. OR construction partition  of aluminum instead of brick wall.
Mon Aug 20, 2018Post  #2
Hello sir,
I have seen a small project which had the slab extended by 4 feet and was taken into room space (but there was an extended beam underneath). But in my case Extension is just 20 inches, so i was thinking that i can take it into room space. What do u say sir.??
Wed Aug 22, 2018Post  #3
        If the slab is laid with the beam than there is no any problem. You can construct 3'' wall of brick or RCC. But keep large size window and ventilator in the wall to reduce the weight, also not put heavy items of house hold in the extending portion.
      Requrds
3837
Roof Beam
2942
RCC Roof SPAN
Last answer on 5/29/2013 10:29:12 AM. by S L Gupta (Civil Engg). Forum started by Rajesh
5861
893
My home is 3 floor, ground Plus 2 floor. But built up with 4" brick walls along
Last answer on 7/3/2020 9:43:54 PM. Forum started by Rohit Kumar
2176
New column footage and pillar very next to the wall of existing building
Last answer on 10/30/2014 5:27:13 PM. by Rachael Suggs. Forum started by Robert
13772
overlap length to steel
1950
3657
2719
734
Hi all. I am constructing my new house. My contractor has built 9 inch red brick
Last answer on 7/25/2020 5:43:09 AM. Forum started by Rishi Panda
2383
house layout plan
Last answer on 7/3/2020 11:09:42 PM. by S L Gupta (Civil Engg). Forum started by Deepak
1815
house layout plan
Last answer on 11/3/2015 11:46:11 PM. by JAI PRAKASH. Forum started by Deepak
2450
Can we construct 4inch wall on extended slab after horizontal beam ?
Last answer on 11/13/2016 12:54:20 AM. Forum started by sravan
2268
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
2841
Water seepage from RCC slab
Centering
What is acre
