Tue May 04, 2010Total posts : 1
amarnath pandey
amarnath pandey
Topic: we have to do the lining of drains and tanks with acid proof tileshow it can be
we have to do the lining of drains and tanks with acid proof tileshow it can be done and how can we select the tiles and acid proof mortars
Wed May 05, 2010Post  #1
Post subject: Reply-we have to do the lining
Dear Amar,
Acid proof tiles  should be according to I.S. 4860- 1968. Acid proof tiles should be low hygroscopic, not easy to oxidized, corrosion resistant against acid and alkali and with the following specifications
  • Water absorption: 2%Max;
  • Breaking Strength: 39.2MPa Min;
  • Acid Resistance: 99.8%Min;
  • Down Quenching Property (temperature difference is 100 Deg. C)
  • No crackle must be resulted in sample after testing one times.
  • Dimensional Tolerance: +/-2mm (<30mm), +/-3mm (30-150mm), +/-4mm (>=150mm);
  • Warp: 2mm Max.
These tiles should be laid with acid proof mortar. Lay the acid proof tiles in the bedding of mortar with the joints between the tiles at least 6mm wide and 8 to 10 mm deep. After the bedding cement is cured and has become dry, pour the hot molten Sulfur cement up to full depth of the joints. Chip the extra cement from the tiles, which can be remelted and used.
S.L.Gupta
2920
Last answer on 4/11/2017 11:10:57 AM. by S L Gupta (Civil Engg). Forum started by vinu
5097
Stop Rats from entering In house via Drain pipe
Last answer on 6/10/2011 11:47:24 PM. by P. Panchal. Forum started by P. Panchal
2474
2969
NEED A ADVICE ABOUT EAST FACING PLAN
Last answer on 7/3/2020 9:50:41 PM. by JAI PRAKASH. Forum started by chandru
1915
acid wash
Last answer on 3/24/2014 1:45:01 AM. by Purvi Panchal. Forum started by Mrs Francis
2105
I have a 1650sq ft flat which I am renovating What company/material I use for a
Last answer on 4/14/2013 3:03:56 PM. Forum started by capt vngautam
2473
What are requirements of drainage and sanitation for dwelling area covered with individual?
Last answer on 6/20/2013 5:14:02 PM. by Sandip Kar. Forum started by g.s.rajan
3158
Basement waterproofing
2251
Hello Sir,I am doing one interior project of a bank but some civil part I am fac
Last answer on 1/24/2022 9:12:12 PM. by JAI PRAKASH. Forum started by Gunjan
1570
2196
2768
2101
2053
I've given 3 bathrooms in a3 bhk flat. I find it 3rd bathroom not necessary.so r
Last answer on 6/3/2016 12:54:15 PM. by S L Gupta (Civil Engg). Forum started by Rsp
1180
Does polyester shrink when it's washed and dried?
Last answer on 1/23/2022 6:06:52 AM. by Celly Swehykol. Forum started by Rolly
2305
1968
Over Head Water Tank
1334
21
25
Preventive
Vastu for Water Tank
Damp
Damp Proofing
Protect
General
