we r a builders in chennai.. we coated the cost 1400 per s.ft., can u tell me ho
Thu Jun 16, 2011Total posts : 2
anbarasan
anbarasan
Topic: we r a builders in chennai.. we coated the cost 1400 per s.ft., can u tell me ho
we r a builders in chennai.. we coated the cost 1400 per s.ft., can u tell me how much rate is mostly charged in chennai area builders? (builder charge)
Tue Jul 16, 2013Post  #1
kishor dhokale
kishor dhokale
Post subject: charges
charges vary depend upon item included.
now as far as your price is concerned,it has shoot upto 2200 including interiors.
Mon Sep 16, 2013Post  #2
feroz khan patthan
feroz khan patthan
Post subject: Cost of Construction in Chennai
Im Designing Buildings in Chennai
As per my experience we can build from 1500/- per sq ft
At present we are doing at
Sembakkam
Madambakkam
191901
2564
Labour Cost
Last answer on 8/5/2014 8:13:30 PM. by JAI PRAKASH. Forum started by ferous
2876
2125
Last answer on 8/19/2013 11:11:40 AM. by S L Gupta (Civil Engg). Forum started by Naveed Mohamed
2746
Constractor cost in chennai(Pallavaram)?
Last answer on 9/11/2013 7:36:05 PM. by laddergrip. Forum started by Manzoor
1777
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
2883
15807
8582
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
8685
i have 15 ft width & 30 ft length plot which ihas to develop tell me the plan &
Last answer on 10/28/2021 12:01:35 AM. by S L Gupta (Civil Engg). Forum started by RANJIT SINGH
2176
2434
5664
What is the cost of the emulsion paint per sq ft as per today's market rate?
Last answer on 2/14/2013 11:17:01 AM. by Jemimmarichardson. Forum started by Rani
3652
1601
sir/madam give tell about loadbearing banhkam as for 8 room roof is an tata 12 f
Last answer on 8/8/2011 4:24:14 PM. by S L Gupta (Civil Engg). Forum started by megha jadhav
18
What is acre
Which types of finishing/ protective coating materials are recommended for Aluminium doors?
Finishing/Protective materials for Aluminum Doors-Primer, Raw linseed oil, Turpentine, Exterior Grade enamel paint......
Tips for Oil Bound Distemper
What is the raw material recommended for painting of metal surface?
Red oxide zinc chromate primer shall be used for iron and steel work including galvanized steel.Zinc chromate primer s..
