Fri Sep 07, 2012Total posts : 1
narsi vekeriya
narsi vekeriya
Topic: wheather to use clc blocks or aac blocks for two sory bunglow
Fri Sep 07, 2012Post  #1
Dear Narsi
Aac blocks are better, read below some of its benifits.
AAC’s improved thermal efficiency reduces the heating and cooling load in buildings.
AAC’s workability allows accurate cutting, which minimizes the generation of solid waste during use.
AAC’s resource efficiency gives it lower environmental impact in all phases of its life cycle, from processing of raw materials to the disposal of AAC waste.
AAC’s light weight also saves cost & energy in transportation.
AAC's light weight saves labour
2838
Compound Wall Construction
13659
3597
2825
1780
what is the size of blocks
Last answer on 3/20/2012 12:26:58 PM. by S L Gupta (Civil Engg). Forum started by Abdul Salam Reki
2075
difference betwen block board and ply board
Last answer on 12/31/2020 2:51:40 AM. by Chetna. Forum started by manisha
1883
Is a apartment block anti-vaastu if it has a pond on its south
Last answer on 3/5/2021 2:56:01 PM. by JAI PRAKASH. Forum started by siddhartha
3850
873
Hi,I have 6 flats in 15 flats apartment,these 15 flats are divided into 3 blocks
Last answer on 1/2/2021 5:27:51 AM. Forum started by Naresh
3938
2032
2004
Concrete Hollow Block Masonry
2242
my plot size is 26X35 west facing and right and left side of plot is block. i w
Last answer on 12/13/2013 11:21:27 AM. by S L Gupta (Civil Engg). Forum started by kailash aute
4183
GLASS BLOCKS / BRICKS
2866
2572
2951
Sir, i am starting new business hollo block machine, where i have ti fix the m
Last answer on 11/16/2021 6:23:48 AM. Forum started by sureshkodiya@rediffmail.com
2537
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by S L Gupta (Civil Engg). Forum started by kamlesh
AuStRalia!!CaNaDa" 91-9056562757 VASHIKARAN sPeCiAlIsT
Last answer on 1/1/2025 11:16:06 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:05 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:04 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:03 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:02 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:01 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:00 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:59 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:58 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:57 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:56 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:55 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:54 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:53 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:52 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:51 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:50 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:15:49 PM. Forum started by Pandit Sahil Sharma Ji
Concrete Decor
Hard
Skylight
Types of Cement
