where are use in 20mm plaster
Fri Oct 21, 2016Total posts : 1
Babasaheb Gite
Babasaheb Gite
Topic: where are use in 20mm plaster
Sat Oct 22, 2016Post  #1
Dear Gite,
        On the rough side of 9'' wall the thickness of plaster should be 15 mm or 20mm.
   In the skirting or dado plaster the thickness should be 20mm.The 20mm plaster is done in 2 coats. Where designing is to be made in plaster than thickness should be 20mm.
Selection of cement ..
3289
what material is used in ceiling other than plaster of paris?
Last answer on 6/1/2011 11:32:44 AM. by P. Panchal. Forum started by GURJEET
3040
2523
1763
1668
2414
COSTING AND STRENGTH OF WALL
7214
Alternative to river sand for wall plastering jobs
Last answer on 1/7/2011 3:36:01 PM. by jaydeep. Forum started by S. Krishnamoorthy
2924
1505
Cemmet Propotion for ceiling
Last answer on 7/21/2015 6:10:11 PM. by vijay. Forum started by vijay
3842
5187
Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
Last answer on 3/25/2011 1:57:52 PM. by Nikita. Forum started by Amogh Desai
2827
4627
time for paint and wall putty
2438
Gypsum Plaster Vs S/C Plaster
2112
Gypsum plastering
Last answer on 7/3/2020 11:51:16 PM. by Purvi Panchal. Forum started by sanu kumar
2781
Plaster work
1738
weather proof repair reg
2727
Present interior design
Last answer on 2/8/2021 11:16:14 PM. Forum started by ENG
Checklist for Cement Plaster
Gypsum
Hard
Skylight
Types of Cement
Specification of ‘Plastering’
Plastering
Plastering
