Home -> Forums -> Construction -> Tile Flooring -> white bathroom tiles for terrace flooring
Fri Oct 16, 2015Total posts : 2
preeti
preeti
Topic: white bathroom tiles for terrace flooring
Hi
Have done cementing, tarcoal paint etc. etc. in the past and nothing seems to work. Please advise if we should go for white bathroom tiles flooring on our terrace. Is there any chance of these tiles expanding or breaking due to Delhi heat.  Also will this take care of our seepage problem.  We stay on the 4ht floor
Fri Oct 16, 2015Post  #1
Dear Preeti
        The best method to finish terrace is
1. Clean the top surface of RCC slab by brooming or iron brush.
2. Apply bitumen painting @ 2kg per sqmeter
3. lay polythene sheet on the bitumen surface.
4 Lay earth on the polythene and made proper slope for drainage of rain water.
5 sprinkle water and lightly rammed the earth and check the slope and it to be on rain water pipe.
6 Lay brick tiles on earth with .5'' mud care should be taken that tiles should be in proper slope and checked with straight edge..
7 Grout the tile joint with cement dust mortar 1;3 ratio.
8. Curing the top surface with water.
9. Do cement pointing 1;2 ratio mortar but care should be taken it should be thin not thick.
10 do curing.
Care should be taken that joint around rain water pipe are fully grout with cement no hollow portion.
Make cement gola with walls.This will also act as heat insulation on roof.
Sat Oct 17, 2015Post  #2
Please follow as suggested.
Tile Flooring-Construction Questions (38)
4041
How to Apply Ceramic tiles on roof Terrace
Last answer on 12/3/2011 10:27:48 PM. by newtondisc. Forum started by Pooja Panchal
2730
terrace floor tile
Last answer on 9/14/2011 2:03:17 PM. by S L Gupta (Civil Engg). Forum started by nitin dahisaria
3896
glass white marble
Last answer on 7/4/2020 2:25:37 AM. Forum started by kamal
2691
Brick tile flooring
Last answer on 7/13/2020 12:31:14 AM. by leelindsey. Forum started by Vinay
3121
2894
Terrace water proofing
14971
Is Jaisalmer stone good for bathroom ?
Last answer on 10/19/2021 11:03:54 PM. by S L Gupta (Civil Engg). Forum started by Radha
2330
3351
1611
flooring white marble in 700sq ft areaestimate plz9718739994
Last answer on 10/4/2016 9:21:30 PM. Forum started by Kamrul
1771
8256
Vetrified tiles
Last answer on 7/4/2020 2:19:15 AM. by S L Gupta (Civil Engg). Forum started by Paragkumar
3075
1543
Last answer on 1/28/2018 4:51:24 AM. by Er.S.K.Jain. Forum started by S.Nagarajan
2291
3382
2048
estimated cost of additional room construction on 1st floor terrace
Last answer on 1/25/2014 11:49:44 AM. by S L Gupta (Civil Engg). Forum started by sujal
2458
what does the vastu says for staircase position that is used from first floor to
Last answer on 4/5/2012 7:27:08 PM. by ABID ALI. Forum started by k.guru prasath
3909
3010
Flooring in Car Porch
Last answer on 5/31/2021 3:06:20 AM. by Keira Nail. Forum started by P. Panchal
3515
What is the specification for vertified tiles?
Last answer on 12/31/2020 1:19:32 AM. Forum started by Kamal Jindal
2691
Brick tile flooring
2894
2610
ceramic tle
Last answer on 7/13/2020 12:22:37 AM. by leelindsey. Forum started by sabakhan
3055
Last answer on 7/12/2020 10:44:29 PM. by Girish. Forum started by joseph
2714
Balcony flooring
Last answer on 7/11/2020 8:10:08 PM. by S L Gupta (Civil Engg). Forum started by sdk
2349
Need Suggestion
2291
2620
Tiles
Last answer on 7/11/2020 8:08:42 PM. by freekundli. Forum started by Ahmed
2485
Vest tiles
Last answer on 7/11/2020 8:07:00 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
1670
1492
I need to know more about this tile n price and dealer near by my place
Last answer on 3/5/2016 10:24:39 PM. by JAI PRAKASH. Forum started by Rakesh
1576
How to Apply Tile flooring in a room
Last answer on 3/24/2014 2:15:29 AM. Forum started by Purvi Panchal
3622
Vitrified Flooring FloorBase on RCC Slabs
Last answer on 5/20/2013 4:10:45 PM. by S L Gupta (Civil Engg). Forum started by Rajesh
2177
down POP designs
2632
tiles
2317
Floor Tile Area difference
Last answer on 7/19/2012 6:28:30 PM. by Ramesh. Forum started by Ramesh
2730
terrace floor tile
Tiles
Tiles for Bathroom
Roof Garden
Bathroom Pictures
Tile
Small
Small Bathroom Ideas or Tips
White
White Cement
You can boost up architectural beauty of your home using white cement since the strength of building and its component..
White
White Marble
Nowadays marble become to be a favorite material for kitchen countertops, sink tops, floors, and wall tiles. White ma..
White
White Bedroom Decor and Design Ideas
In scorching summer white bedroom is best place to relax. A white bedroom always looks classic and beautiful. It make..
Bathroom Cabinets
Tips for Small Space Bathroom
