Home -> Forums -> Construction -> Glass Windows -> window glass
window glass
Thu Aug 27, 2015Total posts : 2
ananth
ananth
Topic: window glass
sir
my home construction ongoing .....I planning to buy glass for window, that are lot of variety of glass available in market.(ex.  single coated/double coated/sun reflected). hence I get confused which will suitable for my home.
so dear expert please suggest me to buy best one.
this one I need answer urgent basis...so please help expert,.
thanks in advance
ananth rajan
Fri Aug 28, 2015Post  #1
Many types of glasses recommended for homes are following:
    • Obscure Glass.
    • Tinted Glass
    • Tempered Glass
    • Laminated Glass
    • Stained Glass
  • OBSCURE GLASS:
This type of glass provides you privacy but allows abundant light to enter the room. This Glass has many varieties such as :
  • TINTED GLASS:
Tinted glass provides additional shading against direct sunlight and warm conditions. This Glass also has many varieties such as :
  • TEMPERED GLASS:
Tempered Glass is extremely strong and often used for its safety features. This is not extra strong but if it breaks, it will break into small pieces like stone. This Glass is ideal for reducing the chance of injury in the event of breakage.
  • LAMINATED GLASS:
This Glass is best for reducing noise. It also resists ultraviolet rays, providing the highest degree of protection from sun rays to your home furnishings.
  • STAINED GLASS
It is a colorful Glass used to create a dramatic effect in every room of your home.
However, stained glass windows have many other useful advantages.
Stained glass windows reduce the intensity of the sun rays and protect your furniture, carpets, and precious woods from long-term sun damage. It will also give you just the right amount of sunlight and privacy.
Tue Sep 01, 2015Post  #2
Use plain glasses if you need sunlight or black one if you do not want or you can use mirror finish if advised by your vastu expert.
You can use toughened glass if suggested by your engineer.
You can use security glass if you have bigger windows and doesn't have railings on it for security reasons.
Glass Windows-Construction Questions (21)
2077
about window glass
Last answer on 11/17/2014 6:11:13 PM. by JAI PRAKASH. Forum started by narendra adkine
1603
Sir my window glass is reflector which is almost transparent please sir suggest
Last answer on 3/5/2018 6:12:48 AM. by S L Gupta (Civil Engg). Forum started by Shailendra Srivastava
1666
painting
Last answer on 10/29/2014 8:55:59 AM. by aravindh. Forum started by aravindh
2583
Door and Window Frames
Last answer on 5/26/2021 7:46:03 AM. by mnabeel_80. Forum started by deepa sangal
2079
Laminate Glass for Wooden Windows
Last answer on 2/9/2014 5:04:29 PM. by Abhishek Garg (Builder & Engineer). Forum started by Ashok V
1958
Last answer on 2/16/2022 8:32:26 AM. by jackthot. Forum started by awdhesh
4165
GLASS BLOCKS / BRICKS
24555
modi guard or Saint gobain?.
Last answer on 12/5/2012 3:24:48 PM. by S L Gupta (Civil Engg). Forum started by raghuam
2116
strong glass to replace grills
Last answer on 1/16/2014 4:27:47 PM. by MANJUNATH. Forum started by ahsan
2880
Alternative for Glass in windows
Last answer on 8/11/2014 9:23:05 PM. by JAI PRAKASH. Forum started by Vinay
5110
2504
how to set this glass in stairs
Last answer on 4/4/2010 3:13:36 PM. by Ajit Tareeka. Forum started by Vivek Kalaskar
2257
Glass of the bath enclosure is gud
Last answer on 3/29/2011 2:12:01 PM. by Swati Sharma. Forum started by rupali
2531
2352
how is installation of glass curtain done, details
Last answer on 6/10/2016 12:48:02 PM. Forum started by neetaa gupta
4929
I want design for glass partition between Drawing room and lobby.Dimensions are
Last answer on 5/12/2015 2:43:34 AM. by JAI PRAKASH. Forum started by ravneet sidhu
2169
what is the cost of a shower enclosure made of toughened glass of 4x4 size
Last answer on 1/25/2021 8:51:09 AM. Forum started by neelam rathi
3874
glass white marble
Last answer on 7/4/2020 2:25:37 AM. Forum started by kamal
1873
Pls send me full information like pants,wooden Glass nd wahpessan
Last answer on 10/5/2014 11:17:43 PM. by JAI PRAKASH. Forum started by Anil Sangwan
2880
2254
glass thickness
Last answer on 11/5/2013 10:37:08 AM. by S L Gupta (Civil Engg). Forum started by Jitender Suhag
What are various types of window glasses recommended for home?
Many types of glasses recommended for homes are following: Obscure Glass,Tinted Glass,Tempered Glass
What are the advantages and disadvantages of glass windows?
Glass windows offers superior Transparency has to be balanced with its relatively low R-value.
Which types of finishing materials are recommended for glass windows?
1.Glass Former: It is the primary material. 2.Flux: It lowers the melting temperature as well as viscosity. ..
What are various types of glasses used in windows?
Obscure glass provides you privacy allowing abundant light to the room.Tinted glass provides additional shading from d..
Types of Glasses
A variety of glasses enriches interiors and exteriors of house and serves the purpose of light, ventilation and decora..
Decorate
What is Glass Window
A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g..
