wiring run above ceiling
Tue Jun 14, 2016Total posts : 2
krish
krish
Topic: wiring run above ceiling
is it safe to run wiring on the ceiling,or run above the ceiling ( with clamps to slab ).
Wed Jun 15, 2016Post  #1
Dear Krish
          If you are planning to lay roof than lay the pipes for wiring in the slab/ roof.If you have already lay the slab than
1. Above ceiling you should lay pipe on ceiling than cover it with cement concrete and it is well within tile terracing.
2. Under ceiling fix with proper clamps.
Mon Jun 20, 2016Post  #2
krish
krish
Post subject: thank u for ur replies.
2962
2256
i wanna knowing about above picture that which matrial used in ceiling & floor
Last answer on 1/27/2010 9:56:17 PM. by Gunjan Utraja. Forum started by dolly jain
2352
Vaastu remedy for duct running above the office area
Last answer on 12/24/2010 9:06:26 AM. by S L Gupta (Civil Engg). Forum started by Shankar
2490
can we running hourse photos in house ?eg- bhagavatgeetha photo (or) a photo fra
Last answer on 11/3/2021 4:46:19 AM. Forum started by suman
3087
1923
chick door
2722
electrical
Last answer on 7/3/2020 9:50:06 PM. by JAI PRAKASH. Forum started by sunil kumar
2255
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
3108
which area of placement is best for running 7 hours according to vastu
Last answer on 2/3/2022 9:21:13 AM. by seema tyagi. Forum started by anil bhatia
1816
WHERE SHOULD I PUT PAINTING OF SEVEN RUNNING HORSES @ MY OFFICE
Last answer on 9/20/2021 8:17:23 AM. by Navneet Jharia. Forum started by SAURABH
17
Get your LOSt -l0ve From v@shik@ran 91 8769373431~CANdan!!!lonDON!!DUBAEI
Last answer on 12/14/2024 2:02:01 AM. Forum started by rupeshji
18
Last answer on 12/14/2024 11:36:35 PM. Forum started by rupeshji
Last answer on 12/17/2024 12:40:06 AM. Forum started by rupeshji
Last answer on 12/18/2024 10:32:12 PM. Forum started by rupeshji
Last answer on 12/19/2024 10:52:12 PM. Forum started by rupeshji
Last answer on 12/19/2024 10:52:19 PM. Forum started by rupeshji
Last answer on 12/19/2024 10:52:26 PM. Forum started by rupeshji
18
Last answer on 12/19/2024 10:52:33 PM. Forum started by rupeshji
What is binding wire
Electrical
Dining
Dining Room Ceiling
How to clean plaster ceiling?
Kids
Kids room ceiling designs
Ceiling
Electric
Electric Shock Proof Home
Living Room Ceiling
Ceiling
Ceiling Lighting
