Home -> Forums -> Construction -> Door Frames -> wood calculation
wood calculation
Mon May 11, 2015Total posts : 2
agg
agg
Topic: wood calculation
please can you tell how to calculate wood for door frames{chowkath} ?
the carpenter is confusing me totally. thanks
Tue May 12, 2015Post  #1
It should be calculated in running feets,
For a door frame of 7*3, total would be 7+7+3 = 17 feets.
Wed May 13, 2015Post  #2
Post subject: Calculation of quantity of wood for Door /window...
Dear  agg, Hello..! Please don't be confused....Generally For Frames of door / window, the Quantity of wood is calculated in Cubic Ft.(CuFt.)  i.e. Length x width x height.,  According to Section of wood its rates may be different. .for door / window  6" x 2.5".  5" x 2.5",  4' x 3" sections are used..
 For a door of size 7'-0" x 3'-0", in section 4" x 3"
      4" x 3" x7'-0" long  x 2 no. = 1.155 cft.
      4" x 3" x3'-0" long  x 1 no. = 0.2475 cft
                                   total     = 1.4025 cft. of required . Hope it is enough...Regards.
Door Frames -Construction Questions (32)
4797
Last answer on 1/13/2014 2:23:28 PM. by S L Gupta (Civil Engg). Forum started by balaji
4330
1759
1485
I would like to know about what are difference and durability with cost about Ru
Last answer on 3/6/2017 4:18:34 PM. by Sree. Forum started by Sree
2033
3740
Door wood and Frame
Last answer on 2/19/2013 11:35:56 AM. by S L Gupta (Civil Engg). Forum started by paresh
2500
Wood quality check
Last answer on 9/1/2015 4:22:59 PM. by JAI PRAKASH. Forum started by Vijay
5060
is neem wood good option for windows , Please suggest
Last answer on 5/24/2016 3:23:11 PM. by S L Gupta (Civil Engg). Forum started by boban
2368
About roof Seelings with wood tuch
Last answer on 9/10/2012 10:45:15 PM. by M Naveed Khalid. Forum started by M Naveed Khalid
2327
Last answer on 11/19/2013 1:31:03 PM. by Amit Hasija. Forum started by Toby Tyler
13969
for kitchen cabinets what type of wood - MDF, HDF, PLYWOOD , is better
Last answer on 7/3/2020 11:24:20 PM. by S L Gupta (Civil Engg). Forum started by ganesan
11409
WHAT IS TH PRICE OF TEAK WOOD IN BANGALORE
Last answer on 12/28/2011 10:07:52 PM. by S L Gupta (Civil Engg). Forum started by ramesh s
2172
How to Protect Wood Furniture
Last answer on 9/8/2011 4:16:04 PM. by davidbanks. Forum started by Justin T
6604
Which chokhat is best wood or iron press or aluminium
Last answer on 8/20/2018 12:28:42 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
4084
need little calcultaion
Last answer on 7/4/2020 12:03:17 AM. by JAI PRAKASH. Forum started by gaurav
1965
I have constructed my house thru one of local contrctr at the rate of 1300 per s
Last answer on 12/4/2014 1:21:13 AM. by JAI PRAKASH. Forum started by mani
2184
Buying wooden furniture
Last answer on 9/30/2021 12:02:50 AM. by Sunchez721. Forum started by Solomon
2241
for wood work in kitchen please give some ideas about design & good material wit
Last answer on 6/4/2021 12:34:00 AM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
1963
WILL PLEASE EXPLAIN GARJAN WOOD CAN IT BE USED FOR INSIDE WOODEN WORK.
Last answer on 10/20/2011 1:57:49 PM. by ajaykapoor. Forum started by ajaykapoor
4735
3219
2858
Column Size and distance
5017
1671
outside main gate
Last answer on 11/17/2020 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Pooja
4084
2689
DOORS
10466
1734
1889
door frame height
Last answer on 12/29/2015 12:49:44 AM. by JAI PRAKASH. Forum started by Pooja
2075
2981
Door window frame
Last answer on 12/16/2013 9:13:21 AM. by . Forum started by Purvi Panchal
3479
Last answer on 3/4/2013 6:35:55 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
Cedar Wood
Hard
Wood
Wood Roof Shingles
Teak
Teak wood frame
Finishing recommended for wood ceiling
There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w..
Garden
Garden Furniture
Garden furniture makes your garden relaxing place to sit. You can choose from a wide range of furniture like benches, ..
Dining
Dining Room Ceiling
