Home -> Forums -> Interior -> Bedroom -> wood work
wood work
Sun May 03, 2015Total posts : 1
vikas b
vikas b
Topic: wood work
I have made all Almira loft  in Precast want to know thr price of wood work i.e., shutter on same. Also cost of wood work in general and type of ply to use  Hyderabad
Sun May 03, 2015Post  #1
Use 18 mm ply for the box and 16 mm ply for the shutters, the ply has to be water proof and termite proof, use .8 mm sun mica for inner surface and 2 mm sun mica for outer part, use 2 mm PVC tape machine edge banding.
The cost would be around 800/Sq.Ft. if using best of the best material. Can be reduced as per the material and brand u select.
2241
for wood work in kitchen please give some ideas about design & good material wit
Last answer on 6/4/2021 12:34:00 AM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
1758
wood work and kitchen
Last answer on 5/3/2015 7:47:39 PM. by JAI PRAKASH. Forum started by vikas b
1551
Last answer on 5/3/2015 7:47:54 PM. by JAI PRAKASH. Forum started by vikas b
3451
can we use VBoard instead of plywood ???????
Last answer on 8/20/2018 12:18:11 AM. by S L Gupta (Civil Engg). Forum started by kavitha
2015
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Last answer on 5/5/2014 2:31:18 PM. by PR Jawahar. Forum started by Anurag
2593
JOINERY WORKS
1789
Sir i have doubt regarding construction . Definitely we will satisfy with your s
Last answer on 9/3/2011 12:38:31 AM. by vijay. Forum started by damodara naidu
1642
work turned out by labour
1420
Trusting the quote of a contractor?
Last answer on 12/14/2013 7:43:37 PM. by nav. Forum started by nav
12792
Construction cost in Bangalore in Feb 2013
Last answer on 3/16/2013 5:18:48 PM. by mani,prasad. Forum started by nithun
2591
want to select paint for Master Bed Room & dining Room
Last answer on 7/2/2020 10:04:22 PM. by Nikita. Forum started by kst
1965
WILL PLEASE EXPLAIN GARJAN WOOD CAN IT BE USED FOR INSIDE WOODEN WORK.
Last answer on 10/20/2011 1:57:49 PM. by ajaykapoor. Forum started by ajaykapoor
2082
Hi all pls suggest me is there any alternate work we can go with for wardrobes e
Last answer on 7/3/2020 11:53:01 PM. Forum started by neeraja_akki
19075
how much is the cost of wood work persquare feet if inside is alaminate and outside is veeneer (costing 100 rs per sq. ft)
Last answer on 4/6/2011 5:53:07 PM. by alagu chendur murugan. Forum started by aslam
1759
1486
I would like to know about what are difference and durability with cost about Ru
Last answer on 3/6/2017 4:18:34 PM. by Sree. Forum started by Sree
2034
3002
House Estimation Breakdown
3397
Bathroom Cleaning Tips
6074
20×60
2029
2606
1805
i need to learn 3ds max
2202
Flat interiors
3624
Wall unit
3470
paint
2574
waterproofing
2540
2548
2509
very nice interior
3143
course interiordecoration
2558
Bye Law
6427
3d max
2580
2373
3186
1648
2321
super
2239
Bed design is this best !
Purchasing Guidelines for Timber
Timber should be of first grade and be free from decay, fungal growth, boxed heart, pitch pocket or streaks on the split
Garden
Garden Furniture
Garden furniture makes your garden relaxing place to sit. You can choose from a wide range of furniture like benches, ..
Cedar Wood
Wood
Wood Roof Shingles
Hard
Teak
Teak wood frame
Finishing recommended for wood ceiling
There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w..
