Home -> Forums -> Construction -> Raw Material -> work turned out by labour
Tue May 09, 2017Total posts : 1
carola braats
carola braats
Topic: work turned out by labour
Good day, can anyone provide me with accurate figures for labour turn out, for rubble stone masonry. As well as any kind of construction element, including concreting, wood work, finishing etcetera. As well as for unskilled labour activity such as digging, hauling and such.
Besides just figures, I am looking for original sources.
I do have some figures, and I have seen IS7272, but both don't match. Also, IS7272 is too limited for the work activity I am looking for.
Many thanks in advance!
Mon May 15, 2017Post  #1
       In my opinion it is  better to take help from Analysis of Rates use in CPWD and these rates are carp orated in Delhi Schedule of rates 2002.
1368
what is the standard labour outputs for different work in is code
Last answer on 7/4/2020 4:30:08 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
3574
construction current rate
4231
labour rate
3475
labour charges rates
5085
3924
3314
what about anticlockwise turn
Last answer on 2/13/2011 1:10:58 AM. by HARISH KHANNA. Forum started by HARISH KHANNA
9157
3650
42596
Labour Cost for Roof RCC work
4010
labor rate for RCC work
2282
2602
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
1844
3397
Bathroom Cleaning Tips
1795
Sir/mamIs it ok to have a staircase in SE side where entrance gate is east but s
Last answer on 8/14/2012 2:22:37 PM. by Gunjan Utraja. Forum started by triveni
1820
3196
labour cost
1833
I want to construt 1200X900x50 mm chamber cover.what will be cost (material and
Last answer on 3/2/2015 11:59:21 AM. by S L Gupta (Civil Engg). Forum started by sachin kale
3075
RCC roof
1970
Marriage hall construction
2536
Function Hall
4200
11102
2189
2037
Estimate
11122
3072
Steel
3037
use of tmt bar
2456
estimate
1761
2991
3605
1943
Cost of Steel construction
1612
2135
READY MIX PLASTER
1864
2223
zero slump concrete
