Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> Which would be a better options for apartments (medium and high rise) Concrete Tanks or Sintex Water tanks
Wed Oct 20, 2010Total posts : 2
savietha
savietha
Topic: Which would be a better options for apartments (medium and high rise) Concrete Tanks or Sintex Water tanks
Hi ,
I have booked a flat in a  medium rise G+4 floor apartment.The project houses two blocks of apartments of  120 and 100 apartments each.
He has completed the construction of one of the blocks. The design engineer is telling that they would provide Sintex(Plastic/ pvc) water tanks for water storage. Some buyers insist on concrete tank while others feel that Sintex tanks are better hygenic and better maintenance wise.
Can any one please tip on the same as which would be a better choice in the longer run?
Thanks,
Savietha Rajaram
Thu Oct 21, 2010Post  #1
Dear savietha
                  The drawback in sintex tank is that the water become hot or cold quickly with the change of the temperature.
Drainage , Sanitary System and Plumbing-Construction Questions (39)
1967
Over Head Water Tank
2221
water supply
6272
Water Tank Quality
2388
5055
6099
What is construction cost
2012
leakage.
Last answer on 7/21/2013 3:08:37 PM. by chethan. Forum started by chethan
7232
2 lakh litre water tank
1844
2375
water tank
2483
1728
1934
2187
3119
1887
water tank motor capacity
10028
OVERHEAD WATER STORAGE TANK
Last answer on 3/13/2013 1:37:46 AM. by Purvi Panchal. Forum started by Purvi Panchal
2775
2205
My house is under construction kindly advice the position of septic tank.Option
Last answer on 9/7/2010 5:46:10 PM. by sabina vanjani. Forum started by piyu sur
1887
tap Connection
3628
sunken slab
2508
How to hire a plumber
3499
1676
2321
3863
flush toilet
1960
4722
Cost estimation for sump tank
2221
water supply
2043
Underground Water storage
2231
sewage pipes
2253
commode & flush type
1949
WC issue
5629
Over-Head water Tank
2340
Vastu for septic tank
2484
2474
Septic Tank Design
3387
3755
Vastu for Water Tank
Preventive
Reasons of dampness
Sewerage
Sewerage & Plumbing System
Water for Construction
