Raw Material
zero slump concrete
zero slump concrete
Sun Feb 08, 2015
Malik Usman
Topic: zero slump concrete
wha is zero slump concrete
Mon Feb 09, 2015
Dear Malik
We just ran across a requirement for no-slump concrete. What concretes are considered to be no-slump concretes?
According to ACI's Cement and Concrete Terminology (ACI 116R-90), no-slump concrete is freshly mixed concrete exhibiting a slump of less than 1/4 inch. Zero-slump concrete is defined in the same document, as concrete of stiff or extremely dry consistency showing no measurable slump after removal of the slump cone. And negative-slump concrete is concrete of a consistency such that it not only has zero slump but still has zero slump after additional water is added.
1763
vishal Thakur
1457
vishal Thakur
3469
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
3432
amit yadav
amit yadav
3275
Last answer on 10/12/2014 9:03:20 PM. by
rajeev
3767
Last answer on 7/4/2020 2:12:02 AM. by
Priti Arora
farid
3769
concrete mix design software
Last answer on 1/21/2021 9:34:10 AM. Forum started by
Robin
2242
sand alternate for concrete
Last answer on 10/9/2010 11:37:42 AM. by
G N Shaikh
manohar
2025
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by
kanwer sajjad
2276
swarup chakraborty
2414
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
2413
Last answer on 10/12/2014 8:50:05 PM. by
sakthi
1618
Last answer on 10/5/2014 2:44:13 AM. Forum started by
tushar bhoj
20123
Last answer on 2/18/2022 6:35:57 PM. by
SusanBones
mani
1785
Last answer on 3/1/2015 8:08:06 PM. by
2106
Last answer on 5/25/2018 12:47:44 AM. by
Raghavendra
1709
Driveway Reconcreting
Last answer on 1/23/2016 8:41:13 PM. by
gpeter
6462
Last answer on 7/3/2020 9:28:50 PM. by
junkie9411
George Kattapuram
3075
RCC roof
Dinesh Bhadu
1970
Marriage hall construction
chandana kumar
2536
Function Hall
Last answer on 6/14/2021 7:48:53 AM. by
Janette
Mark Paraon
4200
Mohan Bhagwat
11102
Last answer on 3/16/2021 12:44:03 AM. by
Mohan
2189
Last answer on 11/19/2020 1:18:18 AM. by
Aamir
2037
Estimate
Last answer on 7/3/2020 10:09:08 PM. by
amzad
amzad
3071
Steel
Last answer on 7/2/2020 10:08:44 PM. by
EvaR
use of tmt bar
sonu.211
1641
work turned out by labour
Last answer on 5/15/2017 1:35:22 PM. by
carola braats
2456
estimate
raj
1761
mohd asif
2991
3605
Last answer on 5/26/2016 3:18:53 PM. by
naresh
1942
Cost of Steel construction
Last answer on 4/22/2016 11:27:17 AM. by
VikasUmate
1612
Last answer on 12/17/2015 2:49:59 PM. by
sushantsah
2135
READY MIX PLASTER
Bimlendra Jha
1864
Last answer on 3/1/2015 8:14:42 PM. by
baskar
Concrete Decor
Concrete Mix Ratio
Ready Mix Concrete
Tips for Cement Paint
