Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> 1st floor partition wall through the center of 14ft x 13 ft room rcc roof
Wed Oct 28, 2015Total posts : 2
Topic: 1st floor partition wall through the center of 14ft x 13 ft room rcc roof
My house ground floor rcc roof work is about to start next week. The bedroom size is 14ft x 13ft, and in future I want to build two room above the bedroom so as the partition wall will run across the center of the ground floor bedroom roof. So, should I provide a support beam through the center of bedroom roof now? if yes, please specify the size and number of tmt steel also.
Thu Oct 29, 2015Post  #1
Dear Vinu
         Lay the beam 9''x9'' with 6 nos 12mm bars and 8 mm rings.
Sun Nov 01, 2015Post  #2
You can have that beam in the Lantel itself at the time of roofing. Take size as 7x4 and take atleast 4 or 6 tmt bars of atleast 16 mm each. Follow Mr gupta suggestion above, If the roofing has been already done. It will act as load bearing beam in both the cases.
S.R. Buildtech - Complete Building Solution
CONSTRUCTION, INTERIOR & EXTERIOR
Services providing in Delhi/NCR
Call Whatsapp SMS: 8802836186
42598
Labour Cost for Roof RCC work
2147
size of house planned 35 ft front and 45 ft depth with 1st floor
Last answer on 5/12/2016 6:07:13 PM. by Lingraj Halli. Forum started by ROHIT KUMAR
3348
1875
2448
interior 4 living room entrance (door) 4m east size 12ft*14ft
Last answer on 10/19/2021 2:25:10 AM. Forum started by nisar
3891
bedroom interior
Last answer on 6/16/2021 4:08:15 AM. by Francisco Reese. Forum started by gajender pathak
11103
2366
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by S L Gupta (Civil Engg). Forum started by gajender pathak
191901
2054
1770
position of partition wall
Last answer on 3/5/2016 10:05:04 PM. by JAI PRAKASH. Forum started by ani
2457
estimate
24767
3287
i want living room partition idea's my room size is 10.5 x 24.7
Last answer on 8/4/2010 10:11:07 PM. by sunilrathi86. Forum started by varu
3380
Square 4 side Pyramid Frame by MS Steel for RCC.
Last answer on 7/29/2014 2:33:14 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Singh
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
What is acre
Glass
Glass Partitions
Do you want natural light in your room or your house is small or you have an open floor plan. You may use glass room d..
