Foundation
About column and beam structure
Thu Mar 02, 2017
Rana kachari
Topic: About column and beam structure
Gupta sir, I want to built a g+1 house with an area of 1684 so ft.
What will be the size of the column and beam of the structure? Can I use 8x10 inch column? What will be the diameter of bars to be used in beam n col.
In the roof, what is the diameter of the bars used for steel mesh. Plz suggest.
Fri Mar 03, 2017
Dear Rana,
The numbers and size of columns/ pillars depends on the plan of the building not on area of building. The size and numbers rods and size of columns are calculated on the basis of load coming on the column.
2616
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
2702
Last answer on 7/3/2020 9:48:52 PM. by
Mohiuddin
2719
Last answer on 5/17/2014 12:39:31 PM. by
gaurav
Yousuf khan
65239
Last answer on 7/3/2020 11:37:34 PM. by
syed
Jitendra Sindhi
1366
Last answer on 7/28/2020 12:37:49 AM. by
vishal singh
Last answer on 1/30/2016 2:05:49 AM. Forum started by
rehan
Last answer on 1/30/2016 2:12:53 AM. Forum started by
rehan
10048
manishkumar
manishkumar
3303
Last answer on 7/3/2020 10:11:02 PM. by
manjula
1764
Last answer on 2/3/2022 7:29:44 AM. by
Akhil George
2749
Last answer on 12/31/2020 2:19:19 AM. by
S.Krishnan
RG MAURYA
14599
Last answer on 7/3/2020 10:42:37 PM. by
mpkumar
mpkumar
2298
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by
Arvind Bhaskar
3657
Arvind Bhaskar
2036
Last answer on 6/16/2015 4:44:30 AM. by
Lawrence
2707
Last answer on 3/12/2021 10:44:44 PM. by
Lawrence
2302
Last answer on 2/22/2022 2:56:11 AM. by
Lawrence
2033
Last answer on 2/1/2022 6:06:54 PM. by
Lawrence
4211
Selection of cement ..
PRAVEEN G
2684
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2140
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2372
structure work
mamtagarg
manish agarwal
5166
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2203
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2821
building a house
nashir
1991
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3089
Foundation
kamal
2272
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1476
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
10048
manishkumar
manishkumar
3660
Foundation
Rohit Sharma
2115
Structure proof checking
Arnab Ghosh
2558
Foundation design
DavidFlores18
nithun
2459
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2467
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3656
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2678
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
3179
satya
13267
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Dining Room Ceiling
