Home -> Forums -> Construction -> Start Construction -> Addition of a floor/storey to an old 3 storey house
Wed Mar 09, 2011Total posts : 8
Vineet
Vineet
Topic: Addition of a floor/storey to an old 3 storey house
We have an approx. 50 year old 100 sq yd house in Delhi. It now has 3 floors - grnd, first & second. Initially it had only ground floor. First & second floors were built over the period of years. But all 3 floors exist since approx. 30 years. We now want to add the 4th i.e. Third floor since it can now be added legally in Delhi as per my information. Thus, we wanted to know: 1) Is there any way to test that whether it is safe to do so i.e. whether the foundation of my house can handle/bear the new floor? 2) What can be done to ensure that the new floor is built safely such that the entire house remains stable i.e. doesn't fall down during construction or due to an earthquake later? Request your help in providing your expert opinions.
Thu Mar 10, 2011Post  #1
Dear Vineet
After reading the content it is advisable to take the service of any Civil engineer/ structural engineer who can give his advice after inspecting the foundation and condition of building.
Thu Mar 10, 2011Post  #2
Vineet
Vineet
Thanks a lot for your response. Just wanted to know that, in such cases, is there a solution? I mean that if the foundation can't handle the load of the new floor then what all things are generally done to resolve this problem? Are pillar-strengthening or new-pillars or foundation-strengthening possible? (frankly, I don't know much about construction)
Thanks for your help in advance ...
Thu Mar 10, 2011Post  #3
Dear Vineet
As I already suggest to you to take the help of civil/ structural Engineer who tell you the solution of adding new RCC pillars or any other solution according to the site condition which dim fit according the condition of building etc.
Thu Mar 10, 2011Post  #4
Vineet
Vineet
Thank you Sir.
Wed Mar 23, 2011Post  #5
Iqbal Sait
Iqbal Sait
Post subject: granite flooring for a three storied commercial ...
I am constructing a three storied building with 2000 Sq. feet carpet area.  I am planning to lay white granite with black spots for the flooring and stairs.   Could you please suggest the right type of granite and the pros and cons of laying granite vis-a-vis vitrified tiles.
Thu Mar 24, 2011Post  #6
Nikita
Nikita
Post subject: Granite vs. Vitrified tiles
Hello Iqbal,
Granite is a better option than Vitrified tiles. As Granite is a hard stone, much durable and strong than Vitrified tiles, easy to clean, resistance to scratch and stains, also better option for heavy traffic area.
Regards:
Nikita.
Thu Mar 24, 2011Post  #7
Hanumanth Kumar
Hanumanth Kumar
Post subject: Marble Selection
I am Hanumanth Kumar from Vijayawada, AP. starting my new house with an area of 231 yards. I would like to know about the flooring. I chose marble for my flooring. I need your advice for what color of marble i need to choose while selecting as i saw 3-4 varieties, like green design on white marble, black design on white , brown design on white, black spots on white marble. In these some are with diamond design, ameoba structure etc, pls suggest me in this as am confused in a lot of varieties.
Thank you very much,
Best Regards
Fri Mar 25, 2011Post  #8
Nikita
Nikita
Post subject: Marble Flooring
Hello Sir,
Don’t be confused, marble is a good option for flooring, and about the varieties you can go with which one you like most for your home. Those are only available in different of colors and styles but pros and cons are same as they are a part of marble. That’s why you can go with anyone you like most.
Regards:
Nikita.
2789
iam looking for a south facing 2 storey modern house exterior(vastu compliance)
Last answer on 4/22/2012 12:03:53 AM. by Gunjan Utraja. Forum started by prakashmunoth
3175
double storey duplex house pictures
Last answer on 4/29/2012 12:17:37 PM. by Amit Hasija. Forum started by mike
3368
6441
Column placement for house
2006
804
1810
1652
2253
3083
3992
2165
want to built double storey in foundation of 2ft.abv. gnd.level,is it possible?
Last answer on 10/19/2012 12:02:07 PM. by S L Gupta (Civil Engg). Forum started by ashish
2255
Sreel pillars(post)
1670
How tall do i have to put the pillars fo double storey duplexfor I see atall cea
Last answer on 11/5/2014 12:27:21 AM. by JAI PRAKASH. Forum started by Rakesh
4651
3795
2030
Need to strengthen brick wall and brick pillar house
Last answer on 5/3/2016 12:24:38 AM. by JAI PRAKASH. Forum started by Sudipto Choudhury
1580
Sir, my plot size is 40'X60' NE facing,i need two storey house plan with minimum
Last answer on 9/9/2016 11:28:32 PM. by bhuvaneshwaran bn. Forum started by sandeep rawat
1644
planning to construct a single storey house very close to the sea
Last answer on 6/16/2014 11:07:07 AM. by S L Gupta (Civil Engg). Forum started by nkumar
3312
2312
How to Paint Old Furniture
Painting
Environmentally
Environment
Environment Friendly Houses
Proper
