Home -> Forums -> Construction -> Layout and House Plans -> Advantages and disadvantages of Steel doors and windows?
Tue Nov 22, 2016Total posts : 3
Topic: Advantages and disadvantages of Steel doors and windows?
I plan to use steel doors and windows ie. www.ileafdoors.com, http://cuirassdoors.com/ etc. instead of traditional wood and concrete. So, I would like to know whether its really rust proof for long years as they claim to be?
Tue Nov 22, 2016Post  #1
Dear Vinu,
         Write in detail what information do you want.
Wed Nov 23, 2016Post  #2
Mainly want to know whether steel windows and doors are rust proof as they claim to be.
Thu Nov 24, 2016Post  #3
Dear Vinu,
           Steel door and window frames are rust proof but need care.
18029
What are the advantage and disadvantages of FLYASH BRICKS?
Last answer on 10/18/2014 4:07:06 AM. by JAI PRAKASH. Forum started by gganesan
1702
Last answer on 7/3/2020 11:20:06 PM. by S L Gupta (Civil Engg). Forum started by PCR.Manohar
3928
7926
3145
What are advantages and disadvantages of iron doors?
Last answer on 1/30/2010 9:20:41 AM. by S L Gupta (Civil Engg). Forum started by rajesh malik
3371
What are the advantages of double leaf doors ?
Last answer on 7/3/2020 10:02:28 PM. by JAI PRAKASH. Forum started by Arvind Bhaskar
2723
can you pl discuss the disadvantages of using higrade steel such as fe 650 700 f
Last answer on 12/31/2020 2:09:55 AM. by H S Rathi. Forum started by Raman
2800
Is it neceesary to have many windows and doors in kitchen as I have got only one
Last answer on 7/4/2020 2:44:00 AM. by PR Jawahar. Forum started by veena
3489
advantages of steel doors
Last answer on 8/31/2011 10:30:21 AM. Forum started by mohit
2185
2423
What are various materials used for windows?
Last answer on 5/14/2014 1:56:15 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
1266
5335
I wants windows and door design
Last answer on 7/3/2020 11:34:08 PM. by S L Gupta (Civil Engg). Forum started by Prahlad Kumawat
2525
6613
what do carpenters charge for doors and windows and wardrobes in lucknow
Last answer on 9/2/2014 10:26:10 PM. by JAI PRAKASH. Forum started by neelam rathi
2894
windows n doors
Last answer on 7/4/2020 2:16:10 AM. by JAI PRAKASH. Forum started by Suguresh Patil
2327
1835
chick door
2690
2924
2188
2184
2790
4520
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
Advantages
What are the advantages and disadvantages of Aluminium doors?
ADVANTAGES:Strength, stability, weatherproof qualities. DISADVANTAGES: Quick oxidation, easily water stained...
What are the advantages and disadvantages of flush doors?
Advantages of flush doors-offer simplicity in design, attractive appearance, durable, good stability against twisting...
What are the advantages and disadvantages of plastic/PVC doors?
Plastic Doors-Termite proof ,tough and durable ,anti corrosive ............
What are the advantages and disadvantages of crazy marble flooring?
Crazy marble flooring is more durable and has refined, regal, decorative appearance..........
What are the advantages and disadvantages of marble flooring?
The marble flooring is more durable...
What are the advantages and disadvantages of glass windows?
Glass windows offers superior Transparency has to be balanced with its relatively low R-value.
Panel
Panel Doors- Advantages and Disadvantages
Panel doors are quite popular in homes for various reasons. Panel doors are hard or provide more security and privacy ..
