Home -> Forums -> Construction -> Home Improvement -> Air Conditioner AC: Tips before buying Air Conditioners
Mon May 12, 2014Total posts : 7
bansalanil96
bansalanil96
Topic: Air Conditioner AC: Tips before buying Air Conditioners
pl. describe the tips keeping in mind for under ground fittings and installations for A.c.in a house.
The comment above talks about the article   " Air Conditioner AC: Tips before buying Air Conditioners"
Mon May 12, 2014Post  #1
SANKARDAS BANERJEE
SANKARDAS BANERJEE
Post subject: Energy Savings.
See 5 Star rating. Obviously Inverter type, which may save up to 60% of energy. Read B. E. E. Norms.
Do not buy over capacity than the actual requirement of you. Take appropriate advice from HVAC Expert.
Mon May 26, 2014Post  #2
PR Jawahar
PR Jawahar
Post subject: VRF AC is the new trend
If one has a requirement of air-conditioning more than one room, VRF (Variable Refrigerant  Flow) with coupled invertor technology is also a good option which could be explored. With this with one outdoor unit you could have many indoor unit so that you could use at your convenience and requirement. This supplies only the required amount of refrigerant flow and uses only the required amount of tonnage. Check it out
Tue May 27, 2014Post  #3
It is very easy to buy A.C. if the buyer knows the functioning of A.C. The technology of A.C. and refrigerator is almost same. The function of air conditioning unit to remove both heat and humidity.  In the functioning of A.C. evaporator coil, condenser coil, refrigerant and fan have main functions. An evaporator coil cools the air inside where as condenser exhaust warm air out side. Air conditioners cool by passing air over refrigerant coils that have fins that look like an automobile radiator. The fan blows the cool air in to the room.See link below
http://www.gharexpert.com/articles/Home-Improvement-2186/Air-Conditioner-AC-Tips-before-buying-Air-Condit_0.aspx
Fri Dec 19, 2014Post  #4
Calvin Shaw
Calvin Shaw
Post subject: window air conditioner
I desperately need a air conditioner for the summer. I am searching for the best brand of window air conditioner in the market. Could you please give some advice. Thanks!
Fri Jan 16, 2015Post  #5
5 star only.
Tue Jan 20, 2015Post  #6
SheriHayes
SheriHayes
Post subject: Portable Air Conditioner
When I bought my Portable Air Conditioner, I just followed these tips:
Find a unit that really is portable.
Buy the right size.
Look for air conditioners with features you like.
Wed Jan 19, 2022Post  #7
jackthot
jackthot
Air purifier is better. That means, in addition to the purchase price of an air purifier, you should also factor in operating costs and filter replacement costs. Operational costs can easily amount to $50 annually, since you should be running air purifiers near constantly to garner the benefits.
Home Improvement-Construction Questions (22)
2347
How to Maintain Air Conditioner?
Last answer on 6/29/2021 4:36:51 AM. by DavidFlores18. Forum started by V K GUPTA
2055
AIR COOLING V/S AIR CONDITIONING
Last answer on 3/13/2013 9:48:14 AM. by Ravi. Forum started by Purvi Panchal
3725
new building aircrack
Last answer on 4/3/2013 5:21:21 PM. by akmurty1. Forum started by Arun
1332
Extension of rcc roof like L shape and passage of air through air holes.
Last answer on 10/22/2020 11:37:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
1418
I am planning to have double height ceiling for my new constructing living room.
Last answer on 2/27/2015 4:03:23 AM. by JAI PRAKASH. Forum started by Arul Prasad
4295
Request Advice
Last answer on 3/5/2021 3:07:01 PM. by S L Gupta (Civil Engg). Forum started by Bimlendra Jha
2431
Electic wires
Last answer on 1/17/2014 12:15:51 PM. by S L Gupta (Civil Engg). Forum started by rajesh
2118
1584
How to close ventilator in Roof
Last answer on 11/18/2013 10:47:10 AM. by S L Gupta (Civil Engg). Forum started by sandeep yadav
1613
Heat recovery ventilation
Last answer on 7/3/2020 10:37:05 PM. Forum started by m z a siddiqui
1397
Last answer on 7/3/2020 10:38:03 PM. Forum started by m z a siddiqui
1989
Heat resistant
Last answer on 2/12/2011 4:01:14 PM. by Nikita. Forum started by arun
18382
1554
2051
vastu tip for west fecing plot
Last answer on 1/22/2022 11:26:02 AM. by S L Gupta (Civil Engg). Forum started by priyanka sinha
2558
Kindly tell vastu tips for west facing plot for construction of dental clinic
Last answer on 10/1/2021 5:05:33 AM. by JesseMWoodley. Forum started by Adarsh
1971
Bathroom renovation tips
Last answer on 2/24/2022 7:21:19 AM. by Messi1999. Forum started by Kirow44
2966
Need tips to decorate small(16X7 ft) drawing room
Last answer on 7/17/2020 2:14:48 AM. Forum started by SANJOY DHAR
1916
Tips on Iron chukhat
Last answer on 8/5/2011 12:07:32 PM. by S L Gupta (Civil Engg). Forum started by Reena Sareen
2580
Last answer on 10/3/2021 3:08:13 AM. by swamy. Forum started by richa
2347
2695
Last answer on 12/31/2020 2:16:45 AM. by anirudhh bagri. Forum started by mpkothari
Central
Central Air Conditioner
Central air conditioners are good option for big houses or large building. And proper functioning of central air condi..
Air
Check out GharExpert buying guide for Air Conditioners AC so that you could know about different types of Air conditio..
Window
Window Air Conditioner
When choosing the room air conditioner, size is important. Many people buy an air conditioner that is too large or too..
Keeping air conditioner in good state is essential to get comfort from scorching summer. This keeps our body and mind ..
what is an air duct
Ducts or Air ducts are used in air conditioning, heating, ventilation to remove or deliver air.
Indoor
Indoor Air Quality
Do you know unhygienic indoor air can create risks to our lives? It can cause asthma, allergic diseases and respirato..
Buying tips for Bricks
Buying
Buying Guide for Garage Door
