Home -> Forums -> Construction -> Start Construction -> Anyone having payment terms for labour contract for house
Thu Dec 10, 2015Total posts : 5
sushantsah
sushantsah
Topic: Anyone having payment terms for labour contract for house
Is 180/sqft a decent rate for labour contract for dehradun city
regards
Thu Dec 10, 2015Post  #1
Pooja
Pooja
It depends upon what is included in contract like tiles, marbles etc. If it is only for civil work, it is too much. I have recently started construction and got rs 120 square feet @ civil work labour contract in amritsar or rs 128 per sq feet if plastering to be done outside the building if no houses built around. I have 10 pillars in building. I m in amritsar city punjab. There is not too much difference in two cities except in metros
Fri Dec 11, 2015Post  #2
       The payment term is as under
1. 20% on completion of foundation
2. 30% on laying Slab/ roof of the house
3 15%Start of wall plaster and completing roof plaster.
4 10% Roof tile terracing, parapet cement plastering etc.
5.10% on floor concrete
6. 10% on exterior finish
7. Last 5% after compeleting  all items   and repair etc.
Sat Dec 12, 2015Post  #3
It depends upon the per day labour rate in your area. It make fluctuate as per the location as well. For me 180 is a good rate inclusive of stone and tile work.
Mon Dec 14, 2015Post  #4
sushantsah
sushantsah
Post subject: there are 1-2 doing tiles (10-12sq/ft) included ...
there are 1-2 doing tiles (10-12sq/ft) included in 180 rs labour contract
but i have heard if you press too much,
contracted might run in between the work,
or use less skilled people.
what you suggest with tiles it will be around 192/sqft then
i have to get an agreement in 1-2 days with contractor.
He made 10-12 decent villas/houses in nearby area with a builder,
means builder outsource to him premium quality houses...
which is verified by house owners know to me that thekadar is good.
reg
sushant
Tue Dec 15, 2015Post  #5
      I am in view let out your contract for work to the good and skilled contractor beside some small higher side rates. If contractor have unskilled than your material is wasted and quality also damaging the work for pinch you life time.
See the link below
http://www.gharexpert.com/articles/Raw-Material-1590/Purchasing-Guidelines-Timber_0.aspx
2283
2770
Last answer on 7/12/2018 5:49:08 PM. by S L Gupta (Civil Engg). Forum started by Hameed
2411
labour
Last answer on 5/14/2013 3:14:12 PM. by Kilyen Rampton. Forum started by dan
2426
Labour only or Labour+Material contracor
Last answer on 7/16/2013 11:00:12 AM. by S L Gupta (Civil Engg). Forum started by Harsh
2201
labour factor guideline
Last answer on 8/8/2011 7:14:57 AM. by S L Gupta (Civil Engg). Forum started by Rajagopal
cost for completion
Last answer on 10/19/2014 3:40:13 PM. Forum started by jithin
2004
What is the cost difference between material labour contract and only a labour c
Last answer on 6/26/2013 4:09:27 PM. by Navneet Jharia. Forum started by nithun
413
Payment terminal.I have been thinking about installing a payment terminal in my
Last answer on 1/5/2022 9:03:26 PM. by HardissonHard. Forum started by Charlie Flint
1314
Economical and reliable choice of type of exterior staircase to the rented 1st floor of house.
Last answer on 12/26/2016 1:12:50 PM. by S L Gupta (Civil Engg). Forum started by vinu
2025
bedroon interior
Last answer on 10/1/2014 8:18:42 PM. by JAI PRAKASH. Forum started by sunil kumar
2384
cost of construction in hyderabad for 80 sq yd
Last answer on 10/27/2015 11:21:28 AM. by S L Gupta (Civil Engg). Forum started by vijaymavarapu
1768
Just finished constructing my house. Where do i start in terms of finishes, deco
Last answer on 10/26/2010 7:34:01 PM. by Gunjan Utraja. Forum started by Mugove Mbundure
3100
my house is not having North-East corner
Last answer on 1/16/2022 10:09:46 AM. by sabina vanjani. Forum started by yogesh
2474
1646
is there any problem having a toilet under the staircase inside the house?
Last answer on 4/5/2017 1:01:34 PM. by S L Gupta (Civil Engg). Forum started by aditya mishra
1461
DOES HAVING STEPS IN THE HOUSE EFFECT IN ANY WAY?
Last answer on 8/8/2017 12:10:09 PM. by S L Gupta (Civil Engg). Forum started by MADHU
2019
2241
what are the rates of labour contract for making bunglow of 4000 sq ft on column
Last answer on 9/11/2012 9:27:30 PM. by sureshkhot. Forum started by narsi vekeriya
3254
Which area measurement in plan is used by contractor to calculate labor contract rate?
Last answer on 5/22/2021 1:49:37 PM. by S L Gupta (Civil Engg). Forum started by vinu
3310
