Basement Plan
Basement Plan
Thu Mar 10, 2016
anandp
Topic: Basement Plan
I want to build the house for 800 sq ft. I would like to build the house like apartment style with beams to raise the home to 9 feet high and use the basement area for other purposes. Being 800 sq ft size home, is it good idea build the house in apartment style or I should construct the house in traditional type to have the house in ground floor.
If I construct house above 9 feet, house much it will cost for Basement, RCC Columns, Beams, Roof. which is the best materials to use for Complete RCC structure including basement, columns, beams, roof.
what is the best roof method I should follow.
Fri Mar 11, 2016
The cost of construction is related with design and drawing and with the specification used during construction. It may be from 1000-00 to 1200-00 per sft see link below
Tue May 03, 2016
You can go ahead with your plan but should contact a good architect for the same. The costing will be around 1000-1200 rs/sq.ft as per the area covered.
4040
Last answer on 2/17/2017 11:54:51 AM. by
pramod
2128
please send me a vaastu plan for a south facing site-size 100ft width brath-20ft
Last answer on 7/26/2009 1:29:45 AM. by
Priti Arora
ruchika
2878
Last answer on 4/27/2011 4:05:44 PM. Forum started by
Laxmi Kant Tanwar
1737
Can we plan garage in basement ? Any design suggestion?
Last answer on 2/20/2013 7:48:04 PM. Forum started by
s.m.sudhan
4995
Input required on Basement parking
Last answer on 7/20/2012 4:07:42 PM. by
vinay
1758
Is Basement allowed in 60*40 site
Last answer on 4/2/2016 11:40:07 AM. by
Surya
4211
Selection of cement ..
PRAVEEN G
2463
Basement - Type and Cost
Last answer on 12/10/2013 12:01:40 PM. by
Ali
2189
Last answer on 11/18/2013 10:57:21 AM. by
adari haripraveen
1922
Last answer on 11/18/2013 10:38:53 AM. by
adari haripraveen
1815
Last answer on 8/15/2015 8:17:49 PM. by
Devender
2486
Last answer on 9/20/2010 8:49:58 PM. Forum started by
A Prasad
2712
BAsement construction
Last answer on 11/8/2012 5:34:56 PM. by
sheree123
Gagandeep
1367
Can I make a basement in the face of North East side plot
Last answer on 1/6/2017 12:06:38 PM. by
Mantu
1652
Last answer on 3/29/2016 11:40:14 AM. by
riaz
2481
Basement Wall in my plot
Last answer on 7/28/2012 6:30:53 PM. by
Naveen Reddy
Naveen Reddy
2467
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by
George Kattapuram
1918
Hi, i am planning to build compound wall (just the basement) for my site. haven'
Last answer on 3/7/2013 2:40:56 PM. Forum started by
lakshmi narayana
5793
Last answer on 8/20/2020 3:44:33 AM. by
mayank
5811
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2865
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2373
Adriano Peres
vamsi
2462
nuksung
2638
dayal
1807
TUNDE
3608
ragha
6254
suba
Basement Design Ideas
Vastu Guidelines for Basement
Basement Ceiling
Basement Flooring
Basement Interior Design
