Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Boundary walls
Boundary walls
Sat Dec 05, 2015Total posts : 8
Pooja
Pooja
Topic: Boundary walls
Hello experts,
I need favor from you guys please. I'm going to construct 2 or 2.5 storey ( G+1 or G+1+0.5). I'm using pillars of 9"*9" using 6 bars of 12mm. My contractor says to use 4.5" wall all around except front boundary wall to save money and according to him there is no need of using 9" wall because weight will be handled by piers( pillar under wall). My plot dimensions are 22.5 * 40=100 square yards
Further, We are not going to build plinth beam and will be using lintel band and roof band.
Your views on this please
Thank you
Pooja
Mon Dec 07, 2015Post  #1
Dear Pooja
        You should  construct 9''x 9'' RCC column/ pillar but use  2nos 12mm and 4 nos 16 mm diameter bars for weight of beam and safety against earth quack.Construct all non load bearing wall 4.5 '' thick.
Mon Dec 07, 2015Post  #2
Pooja
Pooja
Thank you Mr. Gupta,
But should I build boundary walls 9" thick or 4.5 thick?     I mean it it mandatory to construct boundary walls 9"?
Is shree cement is as good as Acc?
How to differentiate that which walls are load bearing walls or non-load bearing walls? I have gone through topic of load bearing and non-load bearing walls already. But still not clear.
Tue Dec 08, 2015Post  #3
The boundary wall has to be 9". All cements are good, the ratio has to be appropriate as per the requirement. Do not confuse with the brand. The outer walls and the wall going from the middle of the plot is can be 9". Do not confuse yourself with load bearing walls as you are using columns which are bearing the load. Take 16 mm TMT in column. 12 mm is not suggested.
Tue Dec 08, 2015Post  #4
Pooja
Pooja
Thank you Mr. prakash and Mr. Gupta,
My last question please. We have very hard soil in my plot. Can I excavate internal walls foundation little less than boundary walls foundation?
Also, I'm considering starting base 23" for 9" wall and 18" base for 4.5 inch wall. M i correct?
Tue Dec 08, 2015Post  #5
Dear Pooja
             For boundary wall 2' depth excavation is sufficient as it not bear any load only have self weight.For internal wall take at least 2' depth from natural ground and take floor level at least  2' high from road or street.
Use 18'' for 9'' boundary wall and 4.5 '' wall. 23'' for house 9'' wall.
Tue Dec 08, 2015Post  #6
Pooja
Pooja
Hello Sir,
By boundary walls I mean external walls of 9" on which lanter will rest. I'm not leaving any space around the building. Did you get the same meaning Sir?  Now according to this , should I follow your advice?
Also, the base of 4.5" internal walls and 9" walls should be same or can I use different? Like
23" for 9" wall and 18" base for 4.5 inch wall? here boundary walls mean exterior walls under which partions will be done
Wed Dec 09, 2015Post  #7
Dear Pooja
        Take 23'' for 9'' and 18 '' for 4.5''
Thu Dec 10, 2015Post  #8
23" is suggested in most of the cases, 90-95%.
2524
1846
5347
estimate for construction of boundary wall
Last answer on 2/27/2015 3:49:38 AM. by JAI PRAKASH. Forum started by vanish
16630
COST ESTIMATE OF BOUNDARY WALL PER FOOT
Last answer on 7/4/2020 3:35:51 AM. by S L Gupta (Civil Engg). Forum started by sira
2863
Need help regarding boundary wall construction
Last answer on 8/27/2013 11:59:55 AM. by S L Gupta (Civil Engg). Forum started by sonu.211
28628
Cost of Construction of boundary wall for vacant plot
Last answer on 7/23/2014 3:21:27 PM. by MANJUNATH. Forum started by Tejpal Singh
1685
hi sir, good morning i have seen your out door boundary wall picture it is des
Last answer on 9/25/2014 8:08:16 PM. by JAI PRAKASH. Forum started by zahid
7024
Cost of stilt parking
Last answer on 5/19/2014 10:08:36 PM. by awdhesh. Forum started by awdhesh
3699
Bounday Wall
Last answer on 7/4/2020 1:58:28 AM. by Manish. Forum started by Nilendu Banerjee
1284
2176
2019
foundation drawing required
Last answer on 8/10/2016 12:58:23 PM. by S L Gupta (Civil Engg). Forum started by AD
1907
Last answer on 5/21/2013 8:56:40 AM. Forum started by Aji
6683
T Junction Plot
Last answer on 6/13/2013 3:10:12 PM. by GULSHAN RAI GULATI. Forum started by Aji
3094
I have constructed a house which is north facing. In the front (Centre) side of
Last answer on 7/21/2020 5:39:31 AM. by Deborah Rangel. Forum started by Anuj Anand
12961
Electric Pole
Last answer on 7/4/2020 2:24:51 AM. by Amit Hasija. Forum started by Anuj Anand
2836
Sample floor plan needed
Last answer on 11/5/2012 9:33:35 AM. by Amit Hasija. Forum started by shyam
7201
North West Corner Missing.
Last answer on 9/4/2010 5:04:44 PM. by Gunjan Utraja. Forum started by nilu
3262
bedroom tree vastu
Last answer on 9/29/2021 7:10:55 AM. by Anil Kumar Mishra. Forum started by Samarjit Roy
5812
3793
9886
2670
4628
4143
2868
5008
3658
1865
2801
2610
2374
2464
2638
1809
3608
6254
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
Beyond
Wall
Wall painting design
