Home -> Forums -> Construction -> Earthquake -> Can a single story house with load bearing brick wall withstand earthquake of scale 7?
Sun Sep 04, 2016Total posts : 1
Topic: Can a single story house with load bearing brick wall withstand earthquake of scale 7?
How earthquake resistant is the traditional construction method of rubble foundation,foundation belt,brick wall,Lintel belt and rcc roof? Can such construction withstand earthquake of magnitude 7?  Also, I would like to know upto want magnitude in richter scale the load bearing brick walls with rcc horizontal reinforcement at three levels but without any vertical reinforcements are safe?
Mon Sep 05, 2016Post  #1
Dear Vinu
        In my opinion you should not have worry about earth quack for single story building. See the link below as this link have 8-10 articles about earth quack, you will be able to know in detail.
Earthquake-Construction Questions (22)
1684
4133
7258
2993
4388
2256
2616
COLUMN nd LOAD BEARING
3005
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Last answer on 9/19/2013 2:12:08 PM. by manishkumar. Forum started by manishkumar
10048
2526
2866
Bricks
3993
2749
3405
Columns and beams
Last answer on 12/16/2020 3:02:45 AM. by S L Gupta (Civil Engg). Forum started by Biju
2213
1834
Last answer on 4/6/2017 10:05:57 PM. by Saurav anand. Forum started by prashant
1606
Want a front elevation of 32* 50 floor plan single story
Last answer on 10/12/2016 11:28:31 AM. by S L Gupta (Civil Engg). Forum started by avtarbagha
23051
Can i have front elevation for Indian homes with single story
Last answer on 7/4/2020 3:07:35 AM. by JAI PRAKASH. Forum started by sanjeevv.verma
1682
earthquake safe building
Last answer on 5/12/2015 2:55:33 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
1837
foundation
Last answer on 10/18/2013 4:09:57 PM. by S L Gupta (Civil Engg). Forum started by yu nandar
2896
Last answer on 12/16/2009 5:20:05 PM. by Asit Patel. Forum started by A.S Rajkumar
Earthquake
What are various types of windows?
Various types of windows are mentioned below: 1. Awning window 2.Casement Window 3.Single Hung Windows
Painting
Brick Arches
