Bricks
Tue Aug 23, 2016
Topic: Can interlock bricks withstand earthquake better than conventional bricks?
Can a house with walls using interlocking bricks and rcc roof with stand earthquake better than a house with wall using conventional bricks with rcc roof?
Wed Aug 24, 2016
Dear Vinu
In my view there is not much difference.
2992
1509
Last answer on 9/5/2016 11:51:29 AM. by
4056
Last answer on 7/26/2012 12:16:09 PM. by
sanjay kumar makhija
2749
Last answer on 12/31/2020 2:19:19 AM. by
S.Krishnan
RG MAURYA
Last answer on 11/3/2015 2:13:21 PM. Forum started by
Techman
1684
Last answer on 11/3/2015 11:52:29 PM. by
Techman
1967
Over Head Water Tank
Last answer on 1/5/2022 12:14:33 AM. by
ananthraj
9196
Vinod
3145
Last answer on 8/16/2013 1:12:41 PM. by
K S SHYAM SUNDER
2866
Bricks
Last answer on 1/16/2013 11:34:07 AM. by
shahidain
3992
Last answer on 7/25/2013 5:11:37 PM. by
LAKWINDER
shahidain
1702
2025
3928
Last answer on 7/28/2015 11:31:41 PM. by
nithin
2350
Vikas
2874
FLYASH OR CLAY BRICK
Last answer on 12/3/2013 11:46:22 AM. by
Abhishek
2708
type of brick
Last answer on 12/5/2013 11:14:47 AM. by
neelam rathi
4179
GLASS BLOCKS / BRICKS
Last answer on 11/10/2021 8:22:17 PM. by
Girish
Girish
7513
Brick Advice Urgent
pmarple
pmarple
2879
Bricks
Chandrasekaran S
2794
brick calculation
Last answer on 4/14/2021 6:20:51 PM. by
Gagandeep
2565
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4894
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2821
srinu
2350
Vikas
3172
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5659
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3238
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5135
Use of Solid Concrete Bricks
aravind
Kinley Tshering
1624
Last answer on 1/20/2017 3:47:17 PM. by
1341
Last answer on 1/16/2017 3:05:19 PM. by
1846
Last answer on 11/3/2016 2:26:29 PM. by
1797
2966
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2230
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1723
Techman
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
