Home -> Forums -> Construction -> Cement -> Cement and Grades
Cement and Grades
Thu Jun 13, 2013Total posts : 1
MANJUNATH
MANJUNATH
Topic: Cement and Grades
Please let me know the differnce between 43 and 53 grade cement. For construction of a house ( Domestic use) which grade is required at various stages of mason work such as  Pillar, Slab, brick work, Plastering, etc
thanks
g.k.manjunath
Thu Jun 13, 2013Post  #1
Dear GK
For construction work at various stages use 43 grade cement for more detail see link below
http://www.gharexpert.com/articles/Cement-1470/Types-Cement_0.aspx
http://www.gharexpert.com/articles/Cement-986/Purchasing-Guidelines-Cement_0.aspx
2680
11571
3430
Type of Cement
2308
cement
Last answer on 8/25/2012 12:33:40 AM. by Ar. Manoj Ralen. Forum started by abhijeet joshi
2809
3025
2509
Last answer on 6/19/2009 8:57:08 PM. by S.Krishnan. Forum started by anil
1718
1385
3750
1990
PPC and OPC cement
2315
Materials
32477
Cost of RCC Pillar
1774
grade of concrete
Last answer on 8/5/2014 8:44:47 PM. by JAI PRAKASH. Forum started by chethan
2678
302 vs 304 grade steel for ralling
Last answer on 3/20/2015 9:55:35 PM. by JAI PRAKASH. Forum started by paresh
1755
Stair Grade Beam
Last answer on 3/30/2017 12:59:46 PM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen
1727
Sand and Cement
Last answer on 8/17/2015 12:51:07 PM. by S L Gupta (Civil Engg). Forum started by gurudatt1825
1740
biggest confusion
Last answer on 12/29/2015 12:52:15 AM. by JAI PRAKASH. Forum started by sushantsah
2395
what are these 3 types
1654
Cement requirement
1774
RAW MATERIAL
3430
Type of Cement
2513
RCC Slab -Curing
2315
Materials
23801
Last answer on 2/17/2021 4:49:34 AM. by S L Gupta (Civil Engg). Forum started by vinu
2855
Types of Cement
2504
Cement
2723
Per Square
Last answer on 6/23/2019 11:56:29 PM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1274
1968
Cracks in concrete roof
1231
Last answer on 5/26/2016 12:44:58 PM. Forum started by SUNIL KUMAR
1728
2254
Cement selection
1863
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by Bhuwan. Forum started by Bhuwan
2887
Cost of Cement Plaster
1846
Last answer on 4/11/2014 2:04:43 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
3025
2423
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by ravi at Dalmia. Forum started by Hemanth
Types of Cement
Density of Coarse Aggregate
Aluminum
Aluminum door finishes types
There are variety of options for aluminum door finishes available. Let’s get to know the types and recommendation for..
Buying
Buying tips for Cement
Tips for Cement Paint
