Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Chances for collapse of modern houses in earthquake?
Tue Nov 03, 2015Total posts : 2
Techman
Techman
Topic: Chances for collapse of modern houses in earthquake?
I'm curious to know the chances of complete collapse of single storey houses constructed following the modern engineering practices ie. Dry pack rubble foundation+RCC belt+Clay/Concrete brick wall+RCC lintel+RCC roof.
How strong earthquakes ie. Richter scale those houses can withstand?
Any idea about how many such houses collapsed in recent earthquakes in India?
Tue Nov 03, 2015Post  #1
Dear Tack man
Earthquake can strike suddenly with very little warning. One minute you may be enjoying the company of your friends and family and the next minute the floor beneath you begins to shake. You cannot stop nature, but you can learn how to react during an earthquake. Single story building have very very little impact of earth quack and negligible chance of complete demolition after RCC belt, lintel etc..
  • The outer shell of the earth called lithosphere is broken into plates which are in constant motion, moving at about the same speed that fingernail grows.
  • Sometimes when the plates rub each other, they stick a little and do not slide smoothly. When the plates push against each other without moving, the pressure is built up.
  • When the pressure becomes more than the edge of the plates can stand, a small part of the plates breaks or readjusts by moving up, down, or sideways.
  • This fracturing, crumbling, or readjustment of the plates releases huge amount of energy and causes earthquake.
  • Earthquakes are due to the sudden release of the tremendous amount of the energy within the earth by the sudden movement at a point called focus.
  • The resulting shock sends out longitudinal and transverse vibrations in all directions in the form of the energy waves which are called Seismic waves recorded on Seismographs.
  • Thus the earthquake affects the buildings by destroying or dislocating of the walls, pillars or roofs
Tue Nov 03, 2015Post  #2
Modern construction is using columns to avoid the same.
1362
How to design my house to be more flood and earthquake safe.
Last answer on 9/27/2018 1:25:04 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
2789
iam looking for a south facing 2 storey modern house exterior(vastu compliance)
Last answer on 4/22/2012 12:03:53 AM. by Gunjan Utraja. Forum started by prakashmunoth
2749
1106
Are TMT's building really earthquake resistant
Last answer on 8/20/2018 12:14:24 AM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
3501
Paint selection
Last answer on 7/3/2020 10:41:47 PM. by Messi1999. Forum started by anwar
2487
new house
Last answer on 8/1/2018 11:41:51 PM. by S L Gupta (Civil Engg). Forum started by kalyan
6455
1000 sqft only ground floor Contrusction Plan ideas Modern home
Last answer on 1/8/2015 11:58:36 PM. by JAI PRAKASH. Forum started by RAKESH NIRMALKAR
2618
modern type pooja room
Last answer on 4/2/2014 2:14:53 PM. by S L Gupta (Civil Engg). Forum started by raj
1877
From where I can purchase sofa's which are showed by your site ??
Last answer on 7/15/2021 11:22:44 PM. Forum started by Taru
3018
Room Dividers
Last answer on 3/23/2015 10:04:40 PM. by JAI PRAKASH. Forum started by PRIYANKA
2753
plz send some circular ceiling designs in modern theme
Last answer on 7/1/2021 5:42:04 AM. by S L Gupta (Civil Engg). Forum started by arpit
1758
How to promote events in modern realities?
Last answer on 4/3/2021 1:31:55 AM. by pilahak911. Forum started by agribalt
2340
Waterproofing leaks from terrace
Last answer on 5/15/2015 11:08:13 AM. by prit123. Forum started by island
3624
Wall unit
2301
17452
i want idea about main door which is teak wood but simple design to make modern
Last answer on 8/15/2013 7:15:40 PM. by GUNA. Forum started by ashok
2503
I have small bed rooms with size 3.35 m X 4 m. What color pattern will make it l
Last answer on 3/25/2010 7:40:53 PM. by shalu sachdeva. Forum started by malimath
4812
PLEASE SEND ME SOME MORE MODERN AND ATTRACTIVE PICTURE OR LINK (URL) OF CORPORAT
Last answer on 2/26/2022 5:07:11 AM. Forum started by abhijit
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Earthquake
Modern
Modern Bedroom
Modern bedroom comprises of pastel color shades, modest designs, and geometric pattern furniture with no carvings, few..
Modern
Modern Style
Modern style interior is based on the principle, “less is more” which means the less furniture you have, the better it..
Modern
Modern Living Room
Modern living room consists of pastel colors, soft furnishing, and sofas with padded arms that always compliment your ..
Modern
Modern Kitchen
You can offer modern style to your kitchen by adding sleek and stylish appliances of stainless steel, granite and lime..
Earthquake
Earthquake safety tips
Earthquake can strike suddenly with very little warning. One minute you may be enjoying the company of your kids and f..
