Home -> Forums -> Construction -> Cement Concrete Flooring -> Colored concrete floor
Fri Oct 21, 2016Total posts : 3
Pooja
Pooja
Topic: Colored concrete floor
Hi everyone,
 Happy dipawali to all of you in advance!!!
Now , Coming to my question. I decided to put colored cement concrete floor. I would be using TATA floor colors
My mason said that he will put concrete mix in the panels and later put float coat (white cement + floor color+ water mixture) of about 6 to 8mm thick layer so that floor can be grinded a little bit by machine and polished for shining. float coat is called panna in some areas.
Now my question is
1. Is it practical or possible to put 8mm thick colored float coat? because I have read somewhere that cement has no bonding properties then how such a thick float will bond itself to the floor?
2. how much time is needed between freshly poured concrete and to put float coat of pure cement-color slurry?
**I dont want to use marble powder as bonding agent in float coat as it may affect where i would be putting only white cement slurry for pure white floor?
3. is it practical to put pure white cement float coat for white floor? any drawbacks in future?
Kindly advice me so that I can make my dipawali as celebration
Thank you
Fri Oct 21, 2016Post  #1
Dear POOJA,
       1.It is possible to put 6 mm floating coat.
        2. Lay the the coat on the next day of laying concrete not later on.
        3. put pure white cement float coat with color.
Fri Oct 21, 2016Post  #2
Pooja
Pooja
Post subject: concrete color floor
Thank you Mr SL Gupta for your quick reply
Sir, What if I want white floor? Can I use pure white cement float coat(without color)? Can a white floor can handle spillage that happens in daily life in homes?
Sat Oct 22, 2016Post  #3
Dear Pooja,
         You can use pure white cement floating coat and good for use in daily life.
Cement Concrete Flooring-Construction Questions (27)
1522
concrete floors
1955
how to colour/dye/stain concrete?
Last answer on 2/12/2013 11:57:42 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3351
1608
Which colour of floor tiles should be fixed as per vasthu
Last answer on 3/14/2017 12:10:29 PM. by S L Gupta (Civil Engg). Forum started by Subbu
2591
want to select paint for Master Bed Room & dining Room
Last answer on 7/2/2020 10:04:22 PM. by Nikita. Forum started by kst
1869
Roof Painting
3589
Per Sq:ft rate for flooring
3842
1767
1460
2029
Need to strengthen brick wall and brick pillar house
Last answer on 5/3/2016 12:24:38 AM. by JAI PRAKASH. Forum started by Sudipto Choudhury
3754
Color scheme
Last answer on 1/25/2021 9:30:37 AM. by Kitan. Forum started by Kitan
3470
Cost of concrete walls
Related to Sunken Slab
15360
2nd floor construction
2635
paiting
Last answer on 7/3/2020 11:21:56 PM. by Gunjan Utraja. Forum started by Abraham
2192
What is the best colour for the inside walls if I want to retain the colour of t
Last answer on 10/26/2010 3:45:23 PM. by nevile. Forum started by Evas T. Bwoye
3350
Study Room Vastu
Last answer on 1/29/2021 7:27:25 AM. by dorishall. Forum started by Avinash Ojha
2328
Roof flooring
1393
3589
1522
concrete floors
1989
1641
floor construction
2122
Floor thickness
2465
Material and cost of Tezzarro flooring
Last answer on 7/20/2012 11:33:53 AM. by S L Gupta (Civil Engg). Forum started by Raj
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Make
Make Your Bedroom WOW
The choice of colors for bedroom paint changes the mood of night. A few notes of energetic wall and ceiling colors lik..
