Home -> Forums -> Construction -> Pillar Work -> Column and beams specification for 5-7 floor house
Sun Aug 07, 2011Total posts : 2
timm todd
timm todd
Topic: Column and beams specification for 5-7 floor house
I have a plot of 16.5ft broad (front) and 30 ft long plot in Delhi. Only the front has a road of 20 feet and it has buildings on its three sides. I would build a ground floor now but intend to have sufficient strength at the foundation level and ground floor level so that I can build 5-7 floors on it later. I do not want to build basement. Also, I do not want to give mat footing as it would increase the cost, instead I want to have columns and tie beams of sufficient strength at ground level and roof level.
I am planning to have four columns of 1ft*1feet along the east wall (column A, I, N, R in the drawing) and four columns along the west (column C, G, K, O in the drawing) wall. Four pillars would be on the east side and four pillars would be on the west side. Columns B, Q and H would also be of 1 ft* 1ft. Other than the columns mentioned here, all other columns of 1ft*1ft shown in the drawing are intermediate columns and will terminate at the plinth level. I am planning to erect columns first and then do the roof, and then place bricks as partition after the centering things are removed. The roof would also have tie beams to bind the building as a single block. The positions are along the outer four sides, along QM, NMLK, IHJG, and LJ.
RQTS is the kitchen. LKGJ is the toilet. QOKM is a room. IHBA is a room. NLJHI is open space for movement.
I require technical advice keeping the map of the house same because I do not want to over construct or under construct.
1. What is the required broadness and number of columns along the east and west walls to support 5-7 floors?
2. What is the required broadness of all horizontal tie beams along all the walls at the ground level to support 5-7 floors?
3. Should two tie beams be given till the road level, one at 3ft in the earth and the other and 3feet above the road as the road is 2.5 feet above the ground level. Are two horizontal tie beams required because I would not fill the space between the two tie beams with bricks? What should be the size of the horizontal tie beams and the number of rods along with the dia of the rod required to be used.
4.What should be the thickness of the rod(12mm or 16mm or 20 mm) in the columns along the east and west walls?
5. What should be the number of rods in the columns along the east and west walls? e.g 16mm along the corners of the column and 12mm along the centre or some thing else?
6. Is Lintel required at 7 feet from road (above doors and windows) and what should be the number and dia of the rods?
7. Is the position of main and intermediate columns correct or can the number of columns be increased of decreased?
8. The nine feet space (AB) along the north wall will have a beam at height 7 feet because the 9 feet span will have no walls. There would be space above the beam as well. What should be the dimension of this beam and what should be the dia of rods used and the number of rods used.
I would be very thankful if you answer my queries as these aspects are important.
Attachments: Final map in visio.vsd on Sun Aug 07, 2011,&n
Tue Aug 16, 2011Post  #1
Dear Timm Todd
I go through the contents sent by you and see you have tried to set columns and other beams etc by your imigination. This type of imigination is good hold up to one or two story building. Your planing is to build 5-7 story building in future. As you should aware that delhi is in sesmic zone may bad hit during earth quacke. The size and design of steel bars of columns are not base on imigination. For all the design proper load to be calculated with other safety precautions. I am in the view that you should arrange structural engineer for this job which will be benifitial.
Thu Aug 18, 2011Post  #2
timm todd
timm todd
Post subject: Footing of columns
Sir, Thanks for your response. I do not intend to go for raft footing. If I plan to go for 4ft by 4ft base of columns at the corners then how should I do it. I am finding it difficult to decide as there are plots of other people beside me who will not allow for the base of the column to come/occupy in their area.
Thanks in advance.
Pillar Work-Construction Questions (39)
1367
3304
3623
2783
2702
2720
1879
Rework required on blinth beam.
Last answer on 10/1/2013 10:53:53 AM. by S L Gupta (Civil Engg). Forum started by ananth
4800
tie beam obsolete
10903
Last answer on 2/8/2021 2:14:37 AM. by John. Forum started by karthik
10048
6549
3129
Plinth beam at ground level
2186
Bending the pillar rods on first floor
Last answer on 10/13/2016 11:16:31 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
10312
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
2559
4212
Selection of cement ..
2691
32561
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2524
Pillar cost
4037
42127
12462
First floor construction
2501
2504
Length of cantilever beam
2537
RCC column (pillar)
9229
pillar size in distacce
9198
2824
2695
1995
2209
3161
Laping length requirement
Centering
Specifications
Painting
Environmentally
